Old 10-19-2006, 10:30 PM
Cview850 Cview850 is offline
Cd player cutting out ?? need help
I jus got my 5x7s and 6x9s put in and they sound great ... its been about 3 days and my cd player quits workin completely so i take my car where i got it installed and he told me my fuse blew and i should have a 0 gauge wire instead of a 4 ... he said as long as i dnt keep it up loud it wont blow but i want 2 beable 2 have it loud ... is there ne thing i can do about this ??? and everytime i try 2 listen 2 my music now it keeps cuttin in and out ... like ill b listenin then it will cut off 5-10 sec then come back then do it again like 40 sec later. Any idea on whats happenin with this issue ?? Thanks
Old 10-19-2006, 10:45 PM
PlayStation3 PlayStation3 is offline
Re: Cd player cutting out ?? need help
wait are you running amps and 4 guage is enough if you are. only subs are what make you need 0 guage wire. and which fuse if blowing the one in the power in line or what we need specifcs
Old 10-19-2006, 11:48 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
sounds like the amp is overheating
Old 10-20-2006, 12:49 AM
Ok im running 2 polk 12" subs to my amp and its 4 gauge amp wires ... then i got a profile 1000 w amp getting crossovered from my sony amp which runs my subs ... the profile amp powers the car speakers ... my 6x9s and 5x7s ... the fuse that blew was under the hood close 2 the battery ... sumethin that unscrewable and replaced ... ne thing else u need 2 kno specific ??
Old 10-20-2006, 01:05 AM
TheBrettster TheBrettster is offline
AF Premium User
could be a number of things. amps are overheating or you clipped your amp due to not putting out enough power. What size fuse are you using?
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
Old 10-20-2006, 08:50 AM
Audio Guy
I would almost have to see this ...... is the fuse that blew something that came with the car, or something the installer put in with the stereo stuff ?
Old 10-20-2006, 02:21 PM
It came with the stereo stuff. The tsunami 4 gauage amp kit thing. The amp isnt overheating because I jus turned the car on and it likes start cutting out already. I dont think i have enough power running but i was running the speakers for about 3 or 4 days before it cut off without no problem. I have no type of clue what fuse it is tho. but i kno that its under my hood and connected to the battery and its like the size of a peanut or a little bigger ..
Old 10-20-2006, 03:33 PM
Audio Guy
I don't know how the guy has it wired up .... maybe the CD player is wired for power to the same place the amp is ? Of course the CD player could be working fine and you still won't hear any sound if the fuse that powers both amps is blown.
Old 10-20-2006, 03:50 PM
thats right ... that fuse powers both amps ... but y is the sound cuttin in and out if the fuse is blown ... it cant b blown ... in my mind i think sumethin is loose ... but im jus tryin 2 find out cause my cash is low and i dnt get paid for another week and it kills me not 2 listen 2 nuthin in my car ... ridin in silence lol ... but ne idea y it cuts in and out
Old 10-20-2006, 07:12 PM
Audio Guy
probably a loose power or ground wire. Find where the amps are grounded and check that screw/bolt.
Old 10-20-2006, 07:13 PM
AF Premium User
Well a quick fix (Temp) would be to get a 100 amp + circuit breaker. There pretty cheap. I'm running 6000 watts and had to get a Optima Battery (200) plus a new alternator (195) Now i never have a problem with cliping.
Old 10-20-2006, 10:25 PM
Like If i do get an optima battery what otherr stuff will i have 2 get 2 install it as a second battery because im thinkin of gettin it in my trunk and running it to the optima battery and running the other amp to my car battery .
Old 10-20-2006, 10:38 PM
alphalanos alphalanos is offline
Your amps are probably going into protect mode.
96 EJ6. Future home of boosted B18C1.
Old 10-20-2006, 11:06 PM
what makes it go into protect mode ??? and what does it do wen it goes in2 protect mode ??
Old 10-21-2006, 07:01 PM
Audio Guy
normally an amp goes into protect mode when if it overheats, the impedance load (speakers) is too low, or there are power problems like a short circuit
