Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 10-19-2006, 08:06 PM   #1
Trans_Am_Zero
Send a message via AIM to Trans_Am_Zero
New 6-disc question
This question has been recirculated so i'm going to pose a new version to get the answers. It has been stated the 6-disc changer being put in in place of the single disk causes speaker problems, so what if the speakers were removed out of a newer Xterra, would the speakers newer speakers work on the other speakers wiring, or am i fooling myself thinking it would be that easy. Also, while we're at it, say I want the steering wheel controls form a 02-04, could i swap my steering wheel (2000 SE) with the one from a 03-04, or could i just take the controls. I know this sounds crazy, but I have a quality junkyard nearby, and the parts are there for the taking, i'm just looking to hear responses before i make crazy mistakes. And finally for reference, if i'm taking the speakers, is there anything stopping me from taking the subwoofer in the back of the 02-04 and putting it with the 6 disc and 02-04 speakers in my 2000. All responses are appreciated
Trans_Am_Zero is offline   Reply With Quote
Old 10-19-2006, 10:32 PM   #2
OffroadX
Send a message via AIM to OffroadX
Re: New 6-disc question
Yes, the 02+ stereo made for 2-ohm loads will not drive the earlier 4-ohm speakers more than moderately.
Yes, swapping in the 02+ speakers as well would be the fix. However, I had a set of 02 speakers (because they were nicer polypropylene vs. paper) and they do not simply drop in. They use a different shape of connector, and physically mount differently. It would take a little work to swap them. I didn't bother and sold the 02 speakers off again.
Steering wheel controls can't be swapped, the necessary wiring isn't present in the steering column (spiral cable) or dash.
The sub-equipped models have an external amplifier. You would need it, and run the necessary wiring, to use the sub.
When did you last check your spare tire's pressure?
OffroadX is offline   Reply With Quote
Old 10-20-2006, 04:55 PM   #3
Trans_Am_Zero
Thanks for the help
