Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 10-19-2006, 05:51 PM
Sphinx8304 Sphinx8304 is offline
Send a message via AIM to Sphinx8304
Exclamation I cannot understand this noise!?
Alright. I purchased a '94 Full Size Eddie Bauer Edit w/ 126.5k. I have checked it thoroughly but i have not found the source for one sound.
When i accelerate, there seems to be a clicking noise comming from the underside of the passenger floor panel. The Ford dealer and my dad said it sounded like an exhaust leak. Checked it and it doesnt seem to be. The seal is actually better than the one on the driver side.
ANYWAY. When in neutral (N), i revved it, and no clicking, when i am driving (D) it clicks when i accelerate to the pitch of the RPM. Only when there is a load behind it.
Any suggestions as to what this might be?
-Sphinx
Old 10-19-2006, 06:03 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: I cannot understand this noise!?
check the EGR and AIR tubes - the load on the engine will change the sound out of them when they leak and both are known for breaking
-=-=-DANE-=-=-
Old 10-19-2006, 07:17 PM
rhandwor rhandwor is offline
Check for a broken heat shield for the converter.
Old 10-20-2006, 08:01 PM
mustangmike351c mustangmike351c is offline
is this 4WD if so check you front shafts I think in 94 they still used u-joints see if they have any play in them. second check the stabilizer links
Old 10-22-2006, 06:48 PM
12Ounce 12Ounce is offline
Disconnect the electrical connector going to the driver's seat for a try.
Old 10-25-2006, 10:29 PM
Truck Truck is offline
I'd suggest the 4x4 lugs on that side. The Hub Centers can grind on the front shaft. Do you have manual 4x4 and leave them ON?
Old 01-23-2007, 08:28 PM
custombronco93 custombronco93 is offline
i have this same problem on my 93 bronco, they said i need 2 replace the hubs, they get loose and rattle when ur driving
Old 02-08-2007, 04:58 PM
huckaday huckaday is offline
Also the hub cover could me lose or have a rock in it.... mine sheared of all but one of the screws on it and made a terrible noise!
Alana
