Old 10-19-2006, 05:04 PM
frank591107 frank591107 is offline
need to remove crankshaft pulley bolt. right or left
can any body tell me. it is so hard both ways I want to know which way is correct. thanks
Old 10-19-2006, 05:23 PM
mustangmike351c mustangmike351c is offline
Re: need to remove crankshaft pulley bolt. right or left
right
Old 10-19-2006, 07:29 PM
rhandwor rhandwor is offline
You may need to go some where they have an impact wrench if you don't have good tools. Some times you need a chain wrench to hold the pulley.
Some times you can use a large screwdriver against the flywheel teeth by the starter. Rember righty tighty lefty lucie.
Old 10-19-2006, 09:04 PM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Ditto on the flywheel. Remove the inspection cover at the flywheel and use a screwdriver or other object to wrench in there and hold it in place. Once it is held you will find the crank bolt fairly easy to pop off... unless some moron used gobs of loktite.
Old 10-20-2006, 10:37 AM
thank you all for your help
