Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-19-2006, 04:15 PM
Slider28 Slider28 is offline
Fan Won't Work on Hi..-Cutlass
I have a 83 Cutlass Supreme Brougham and when i put the A/C fan switch on HIGH it turns off. I have replaced the switch and it still has the same problem.. Can somsone give me an idea to whats wrong. Someone said its probably a bad connection but i have wiggled the wires at the relay and tapped on the relay and still nothing.
Thanks,
Chaz.
Old 10-19-2006, 06:58 PM
maxwedge maxwedge is offline
A990 racer
Re: Fan Won't Work on Hi..
Welcome to AF, check the link, the blower circuitry diagram should allow you to trace the problem http://autozone.com/servlet/UiBroker...3d801353a2.jsp
Old 10-20-2006, 01:43 PM
Ok. I found the problem after i replaced the fan relay. But need help on this one too. The RED wire that comes off the Fan relay and goes to a connector with 4 wires (The red, light green, dark green and black) connect the other end with (red, green and black) the connector is a 4 to 3 wire,( the connector was burned to a crisp so i cant tell what wires connected to which and i dont see it on any of the scematics. can someone teel me what wires to splice together?
thanks again,
chaz.
