Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-19-2006, 12:41 PM
acthreee acthreee is offline
93 problems
Hi, I have a 1993 I'm TRYING to bring back from the dead(hardtimes). I've replaced ICM, coils, plugs, wires, O2 sensor,batt, alt, cleaned up batt and ecm grounds and flushed trans and unplugged TCC.
This car is evil, it shakes and will occasionally cut out and is very hestitant. It is definitaly running rich and smells of gas out exhaust(no leaks though).
I hooked up a Tech 1 and there is no codes. All of the sensors are good even tested them with a voltmeter. The only thing is the new O2 sensor voltage goes up and down erratically from .1- .9v. The scanner displays that the car is running lean, which its not. I don't get it is it a bad ecm, timing chain, cam etc... I know I've got a bad motor mounts as well. Does anyone know how to do a simple inj. test as well, they are getting proper voltage.
The car is very hesitant when cold and runs like a toilet when it is warm. though at a steady mid rev it sounds and runs good out of gear. Thanks for reading, I guess I'll give it another go tonight!
Old 10-19-2006, 03:32 PM
maxwedge maxwedge is offline
A990 racer
Re: 93 problems
Check fuel pressure, check for fuel in the press reg hose, check coolant temp sensor reading warmed up also. Disconnect maf see if the car improves any.
Old 11-06-2006, 01:56 PM
Re: 93 problems
FINALLY!!!! New fuel regulator, filter, gas and brake lines (very rusty, broke them getting filter off!), pcv, new inj, new tpc, iac, ign mod., coils, wires, plugs, crank sensor, evey vacuum line possible, ecm, I even changed the bloody motor mounts it was shaking so bad!!, Tcc solenoid, throttle body gasket, maf sensor, hours and hours of voltmeter testing and ground cleaning, was about to do timing chain but thought I'd check the coils (even though they were new) All of this equals.......................................
Broken spark plug on cylinder 2!!!!!!!!!!(was the first thing I changed of course)I almost had a little cry, hehehe.
