Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-19-2006, 12:11 PM
kcp1 kcp1 is offline
help!!!!
I have a 2001 ford explorer xlt. if you push the gas pedal all the way it will go really slow until it reaches 25 mph then it just takes off
Old 10-19-2006, 12:52 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: help!!!!
If you ease into the accelerator gently, does it accelerate smoothly, or still seem to bog?
-Rod
Old 10-19-2006, 10:16 PM
Re: help!!!!
I try too explain a little better. it does do the same thing when you accelerate slowly and i should say that it only does this sometimes. also sometimes when your stopped when you start going it feels like the front of the car is shaking.
Old 10-19-2006, 10:17 PM
Re: help!!!!
one more thing sometime when your going 30 and you try to speed up to around 40-55 it does the same thing where it won't accelerate almost at all
Old 10-19-2006, 10:37 PM
shorod's Avatar
SHO No Mo
Re: help!!!!
Sounds like your Explorer is in need of a tune up, and have the vacuum lines looked over. You may be experiencing a misfire under load due to worn spark plugs, arcing spark plug wires, restricted fuel filter, weak fuel pump, dirty fuel injectors, restricted air filter, etc.
As part of a tune up, I would expect the plugs to be checked and or replaced, the plug wires to be inspected and/or replaced, the fuel filter to be changed, and a bottle of fuel injector cleaner added to the fuel tank. The air filter should also be inspected and probably replaced. This seems like a good place to start based on your descriptions.
Other items to check: coolant temperature sensor, oxygen sensors, fuel pressure, mass airflow sensor, throttle position sensor, EGR valve.
-Rod
Old 10-19-2006, 10:47 PM
Re: help!!!!
thanks for the reply try all of that. I just had my fuel filter changed two days ago
you gotta be one of the smartest people on this site
Thanks!!!
