Old 10-19-2006, 10:51 AM
Jamme's Avatar
Jamme Jamme is offline
Send a message via MSN to Jamme
WIP Aston Martin DBR-9 Model Factory Hiro
Hello to everybody,
While i'm busy with the FXX's WIP, i've started another one.......
Here are a few pictures from the body primed:
The difference between the Renaissance and MFHiro are big.
On the Hiro, the cover on the front wing is a White Metal piece that needs to be glued in place, as is the front panel. This means that, for MFH, it is quite easy to make other versions without having to make another body...
All the vents are closed on the MFH model, so I decided to open them:
I also opened the exhaust hole, with a 3mm drill, to insert later a piece fo Tube for the exhaust.
That's all for the moment.
Thank you for looking
Thank you also for your comments and critics.
Nest step: sanding, white primer and sanding, painting and first coat of varnish.
Cheers,
Jamme
Old 10-19-2006, 12:03 PM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
Re: WIP Aston Martin DBR-9 Model Factory Hiro
Oh that's a great WIP! Which version is it, it looks like Silverstone 05? And what color will you use?
I ordered mine (lemans 06 version) from Hiroboy couple days ago, can't wait till I get the package
Old 10-19-2006, 12:15 PM
Jamme's Avatar
Hello, and thank you for posting.
It's the Le Mans Version 2005
(the silverstone version has the louvers on the front wings)
The color will be Middlesex Green with smal metallic parcels, from Dupont, mat basis (Centari 600).
You will see when you get it.........it's a great kit.
By the way......incredible work on your Mc Laren, I love it.
Hope to see it one day......As you live in Germany and I in Belgium, we are neighbours.
Cheers,
Jamme
Old 10-19-2006, 01:07 PM
klutz_100's Avatar
Jamme, great to see you working on this kit!!
Very good start.
This will be my next project so I look forward to learning from you. Give lots of details please
What are your plans for the rear diffuser? It looks VERY out of scale to me.
@ TheSaint111 - I got paint from hiroboy. Did you?
BTW, I'm your neighbour on the other side - I'm in Poland
Old 10-19-2006, 01:38 PM
5ynergyx's Avatar
5ynergyx 5ynergyx is offline
This is a very cool kit!
Old 10-19-2006, 02:44 PM
davesans's Avatar
davesans davesans is offline
Great start I will be watching this one close.
Regards,
Dave
Old 10-19-2006, 07:55 PM
KevHw's Avatar
KevHw KevHw is offline
Can't wait to see this finished. One of my all time favourite cars.
Old 10-20-2006, 08:20 AM
Decs0105's Avatar
Registered User
hey neighbours
I ordered the paint from Hiroboy too, I think it's mixed from the color code so it should be a good match.
Old 10-20-2006, 09:53 AM
drunken monkey's Avatar
Razor Sharp Twit
fantastic.
i was hoping to see someone build one of the newer MFH kits.
I've been eyeing up the Aston Martin DB4GTZ kit for ages....
AF's Guidelines
Read them.
Old 10-20-2006, 01:10 PM
sam01contact's Avatar
sam01contact sam01contact is offline
Nice bodywork! I will follow this thread closely!!
Old 10-21-2006, 02:45 PM
Decs0105's Avatar
Registered User
I got my DB-R 9 today and your're right, it's a great kit!!! But I noticed something I have quite a big gap between body and chassis at the back of the car. That results in a problem that the chassis won't be on the same level as the body, I hope you get what I mean . Do you have the same "problem"?
And one more thing what did you do to get these sharp panel lines?
Old 10-21-2006, 03:53 PM
klutz_100's Avatar
I have the same thing on mine.
I haven't ally studied the kit yet but my guess was that it will be fairly easy to fix with some sanding.
Old 10-21-2006, 05:03 PM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
I 've waiting to see someone working on these, I keep meaning to save one for myself but they all sell out to fast, Maybe this time as a new shipment is on it's way from Japan.
The paints I supply should be 100% correct, I have a freind who does work for Aston Martin in the UK and he got me the info for the paint.
I will ask MFH about the fitemnt problem with the base.
Steve a.k.a. Hiroboy
Old 10-22-2006, 04:46 AM
Decs0105's Avatar
Registered User
Thanks Steve, please post it here when you know something.
So I am not alone with this . I am not quite sure about fixing it, the diffusor lays tight at the body and I don't know how much you can sand away without "ruining" the shape of the back... btw that reminds me that I need some more DB-R 9 pics
here you can see that it's just the middle that doesn't fit good, the back with the diffusor is quite ok.
but now back to the progress please
Old 10-22-2006, 10:14 AM
Jamme's Avatar
Hello, I got the same problem.
When you "push" on the chassis, to the body, it is better, but, anyway, it is not flush.
Personally, I think I will leave it as it is, because Ithink the sanding will be à Problem.......
Greetings,
Jamme
