Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 10-19-2006, 02:13 AM
projectmaxrpm projectmaxrpm is offline
2003 gts front ecu ticking
My buddies 03 gts eclipse is having major issues, battery is dead, front ecu is ticking and when u goto jump the car all lights come on inside and out and washer sprays, wipers...wipe and wont start. what could the problem be plz help
Old 10-19-2006, 02:30 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: 2003 gts front ecu ticking
um....call a priest, you will need a young one, and an old one.
Seriously though, not sure. Has the car been flooded (like, submerged in water or anything), all the connections are good and clean and tight, starter is good...with all those different things I have no idea where to even look. If it's under warranty or anything go to the dealer, and even if not, you will probably need a mechanic to give you any real answer.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 10-19-2006, 09:37 AM
808drifter 808drifter is offline
sound like a fried relay to me.
Old 10-19-2006, 10:24 AM
well were gonna replace the front ecu and the battery terminal for the positive side but who know 3rd gen....gooosh
Old 10-19-2006, 10:27 AM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
try the starter relay and a fresh battery. i think that should do it, the ECU shouldn't be the problem.
starter relay may or may not only be attached to a new starter...
Don't act like you don't love it.
503/2000
