Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-19-2006, 01:40 AM
milkdudski milkdudski is offline
00 problem with tranny?
Two days ago I noticed a loss of horsepower going up mountain. Today I noticed when accelerating the rpms are going much higher past 5000 before car accelerates at 60, normally rpms about 3500. While cruising at 70 on level road I hit the gas and the engine increased rpm by 1000 but car stayed at 70mph . When cruising at a steady speed up a constant grade I can feel the car lose horsepower then within 5 seconds its is back. Is my tranny slipping or is there an electronic malfunction? Car has 105000 miles on it but the tranny was replaced under warranty at 28000. Fluid flush every 30000 miles and was done at 93000 miles. Fluid normal color and no burnt odor. Help.
TY
Old 10-19-2006, 10:53 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 00 problem with tranny?
- tranny has self diagnostics, try if that gives any indication
- seems like slipping. There can be lots reasons from low charge voltage to solenoid/valve /bands /filter blocked /malfunction. (on some models valve assembly may be swapped while tranny is on)
- check links http://www.cardomain.com/ride/748507/24
