Old 10-18-2006, 08:35 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Front end swapping thread
Anybody positively know if you can swap an 03+ Sunfire front end onto a 95-99 Cavalier? Also, you can swap an 03+ Cavalier front end onto a 95-99 for sure, correct? Or is it true that all 3rd gen body frames are all the same for 95-05 Cavaliers and 95-05 Sunfires?
Old 10-18-2006, 09:26 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Front end swapping thread
Anything 95-05 can be swapped front end wise. Whether it be from a cavalier to a sunfire or vice versa.
Doing a cavfire conversion requires a little more swapping around different year cavalier front end. To do a sunfire, your going to need the crush guard as its formed toatally different than a cav. It has a sharp point.
95-99 Cavalier
- 95-99 Cavalier Headlights(with plastic mount, its what bolts down the headlight)
- 95-99 Corner Lights
- 95-99 Front Bumper
- 95-99 Fenders (recommended) or the Corner Brackets from the fenders
- 2 x 9005 High Beam Bulbs
- 2 x 9006 Low Beam Bulbs
- 2 x 194 Bulbs for turn signals
- From the donor car's wiring harness, two 9005 and two 9006 headlights sockets and two 194 corner light sockets(Only needed if you have a 00-02 Cavalier, all the rest have this bulb already wired on your side markers or part of your turn signals)
- Black L shaped bracket for bottom of headlight to slide into...found from Donor Car. Clicky
00-02 Cavalier
- 00-02 Cavalier Headlights(with plastic mount, its what bolts down the headlight)
- 00-02 Corner Lights
- 00-02 Front Bumper(or you can modify a 95-99 to work, trimming on the headlight area is what needs to be done)
- 00-02 Fenders(95-99 can be used IF and only you cut off the bracket that holds the 95-99 turn signals on)
- 2 x 9007 High/Low Beam Bulbs
- 2 x 3157 Turn signal Bulbs(any 3rd Gen has these for turn signals so not necessary unless you need new bulbs, you can use what came with your car)
- From the donor car's wiring harness, or two 9007 headlight sockets(unless you have a 95-02 Sunfire, or 03-05 Cavalier, these already use this bulb for headlights)
- Corner Bracket, this holds your 00-02 Corner Lights by one of the prongs on the back of the light, this is not necessary some have said.. but I wouldn't want to risk the corner light falling out, but its ur choice Clicky
03-05 Cavalier
- 03-05 Cavalier Headlights(with plastic mount, its what bolts down the headlight)
- 03-05 Front Bumper
- 03-05 Fenders(00-02 can be used, IF you remove the corner bracket if you have a 00-02, also 95-99 can be used IF and only you cut off the bracket that holds the 95-99 turn signals on)
- 2 x 194 Bulbs for turn signals(any 3rd Gen(except 00-02 Cavaliers) have these for turn signals so not necessary unless you need new bulbs, you can use what came with your car)
- From the donor car's wiring harness, or two 9007 headlights sockets(unless you have a 95-02 Sunfire, or 00-02 Cavalier, these already use this bulb for headlights) and two 194 corner light sockets(Only needed if you have a 00-02 Cavalier, all the rest have this bulb already wired on your side markers or part of your turn signals)
95-02 Sunfire
- 95-02 Sunfire Headlights(with plastic mount, its what bolts down the headlight)
- 95-02 Front Bumper
- 95-05 Fenders
- From the donor car's wiring harness, or two 9007 headlights sockets(unless you have a 00-05 Cavalier, these already use this bulb for headlights) and two 194 corner light sockets(Only needed if you have a 00-02 Cavalier, all the rest have this bulb already wired on your side markers or part of your turn signals)
03-05 Sunfire
- 03-05 Sunfire Headlights(with plastic mount, its what bolts down the headlight)
- 03-05 Sunfire Turn signals
- 95-05 Fenders
- 2 x H11 Low Beam Bulbs
- 2 x H9 High Beam Bulbs
- From the donor car's wiring harness, or two H11 and two H9 headlights sockets and two 194 corner light sockets(Only needed if you have a 00-02 Cavalier, all the rest have this bulb already wired on your side markers or part of your turn signals)
- Corner Light brackets, this is basically a bar that bolts to the bottom/side of the corner, which then bolts to the frame in the front next to where the headlights bolt down Clicky
- Bumper Brackets, these brackets bolt from the metal bumper support to the bumper cover (Pic 1, clicky) (Pic 2, Clicky)
That should answer everything for ya.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 10-18-2006, 09:40 PM
Lances133's Avatar
Thanks, I looked on the sticky on Jbo and saw all that but it didn't say anywhere that everything from either 95-05 cav or fire had the same bolt patterns, that's all I needed to know and didn't wanna ask on there for fear of getting burned at the stake.
Old 10-21-2006, 11:57 PM
Derk_eliso's Avatar
Derk_eliso Derk_eliso is offline
Send a message via AIM to Derk_eliso Send a message via MSN to Derk_eliso Send a message via Yahoo to Derk_eliso
well, only one way to find out
