Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-18-2006, 07:37 PM
ivan819 ivan819 is offline
Help With My 93 Explorer
My 93 Is A 5 Speed When You Are Driving I'm Getting A Whinning Noise From The Trans,but When You Push In The Clutch The Noise Stops Any Help Out There
Thanks
Old 10-19-2006, 07:31 PM
rhandwor rhandwor is offline
Re: Help With My 93 Explorer
Do you here the clutch slipping or a whine from the transmission. Check fluid levels first.
Old 10-20-2006, 07:39 AM
No I have had the clutch replaced twice by Firestone.Jan/2006 and again in oct/2006
Old 10-20-2006, 08:48 AM
Put the vehicle on jack stands and with the vehicle running use a long screwdriver and listen to where the sound is coming from. It could be a universal joint or a whine in the transmission. Try to determine the exact cause. Make sure if any u-joints have been replaced they are lubed and check the transmission fluid level. For some reason most quick lubes don't check the transmission level.
Old 10-23-2006, 06:04 AM
Okay on saturday I called the ford dealer ship they said that i had an aluminum casted transmission so I put transmission fluid in the transmission. It still whines. I replaced the rear u joints in the truck last year also. The whine sounds like it is coming from the transmission. under the stick shift etc..
Old 10-23-2006, 12:54 PM
You could pull the top under the shift lever and try to determine what it is coming from. Just buying parts is going to be close to a used transmission.
Try slightly moving the shift lever and see if this increases the noise level.
How low was the transmission fluid level. You could check for some additive that might help.
