Old 09-07-2002, 02:51 PM
VTECoDeloSol VTECoDeloSol is offline
Question Engine Swap
Does anyone know if the B18c5 will swap into a del Sol? Also, what other changes will be needed if it can?
Old 09-08-2002, 02:28 AM
b16a3sol b16a3sol is offline
the swap is a straight drop in. everything you will need to swap the motor into a civic or integra will also be needed to drop it into the del sol. engine, tranny, ecu... and all that good stuff will have you kicking some ass in your type r motor. make sure you get the LSD with that so you can really have some fun.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 09-08-2002, 09:41 PM
can i hook a turbo kit up on it?
..... i never seen any turbo del sols before .......
Old 09-09-2002, 02:15 PM
s2Ksol s2Ksol is offline
There are a lot of turbo sol owners out there. I have seen turbo's on d16's, b16's, b18's. There is a sol in the new sport compact car with a turbo on it.
The c-5 package will run at least $5k then add on labor for install. I think the b18c1 (gsr) is a cheaper route with still a lot of power to build from. The GSR has 170hp with 128 lbs of torque.
Blair 95 VTEC
www.teamsolil.com
dakota engine swap jpuckett13 Dakota 0 08-23-2010 07:21 PM
1995 olds achieva engine swap help. handymann3 Achieva 2 01-21-2010 09:26 PM
engine swap Cadillakin'98 S-10 1 10-22-2009 09:33 AM
engine swapping E. Frank Performance 6 08-07-2009 06:37 PM
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
