Old 10-18-2006, 04:30 PM
Highrisk82 Highrisk82 is offline
Arrow Transmission-Diamante to 3000gt HELP!
I have a 94 3000GT Non turbo v6 dohc and the transmission blew . will a transmission auto/overdrive out of a 1994 diamante sohc, will this bolt up to my car. Please RESPOND I NEED AWNSERS!!!!!!!!!!!!!!!!!!!!
Old 10-18-2006, 07:53 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Transmission-Diamante to 3000gt HELP!
Originally Posted by Highrisk92
I Replaced Teh Tcu But More Importantly The Id On The Tranmission What Should I Look For And What Dowhen I Get The 2 Id Then What What Do I Do From There
umm...look for the transmisison ID. according to the manual, the ID on your 3000GT atx should be F4A33-1-MNP8, or something of that sort. simply look for a number like that on the 3000GT atx, and on the Diamante atx.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-18-2006, 08:29 PM
Igovert500's Avatar
blue + red light magnet
OK I know a guy on 3si with a 93 dohc 3000gt using a diamante ATX tranny....not sure what year/model diamante it came out of though. I do believe you have to relocate the dipstick though.
Also found this, which would indicate not all can be interchanged
This, says 92-97 are the same
sorry it's not a definitive answer, but I'm on my way out and thats all the research I had time for. Like Linebckr said, check the tranny ids. Hope this helps somewhat.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-19-2006, 01:52 AM
Morphius289's Avatar
Morphius289 Morphius289 is offline
How the hell do you know these things???
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 10-19-2006, 03:30 AM
Linebckr49's Avatar
haha. ya, it sounds as if i just have oodles of information stored in the recesses of my brain. i wish. i got it from the service manual. i was gonna post a pic of the tranny code/engine list, but i decided not to. but here it is, just for your viewing pleasure, Morph:
93 3000GT base
