Go Back   Automotive Forums Car Chat > Mercury > Villager
Old 10-18-2006, 12:21 PM
perdi68 perdi68 is offline
1995 villager leaks oil
just purchased a 95 villager and it seems to be leaking oil after it has been drove and then turned off?Changed PCV,had a Full oil change done also.Problem is still there.Any ideas on what the problem maybe?
Thanks for any suggestions.
Old 10-24-2006, 09:28 PM
rsmith8411 rsmith8411 is offline
Re: 1995 villager leaks oil
I've got a 93 Villager that developed an oil leak at the rear main seal (the oil dripped out of the bell housing). Uh-oh. This is a big job. Out of desperation I bought some Lucas oil treatment and used it at the next oil change and it got better. Two oil changes later and I'm healed. I've even gotten the courage to park in the driveway! At my oil change I just substituted one quart of Lucas for a quart of my regular Valvoline oil. It's expensive (about $9 per quart) at Autozone, but much cheaper than the alternative. Lots of people swear by it.
I've also had leaks at my oil pressure sending unit. Just replaced it. You need to figure out where the leak is first, then have at it. I've always cringed when I see oil under my vehicle, but it usually is something simple.
