Rear hatch lock cylinder
I need to replace the rear hatch lock cylinder on my firebird. it seems to be riveted in place...does anyone know how I get the old one out and install the new one?? Any help would be much appreciated
Re: Rear hatch lock cylinder
I forgot to mention that it's a 1991
I changed my window motors and i had to take out the whole Window motor with the Regulator attached to it. This was riveted onto the door. I drilled a hole through the rivets and then hammered them off if they didnt come off by drilling. I Replaced the rivets with Some nuts and Bolts. If you have a rivet gun you can replace it with that but from what i hear those are expensive and they are a big pain in the butt. |
yeah! rivets suck AAAAAA. go for nuts/bolts, make sure you get a nyloc, use threadlock, or double nut it so it wont fall off cuz of vibration..
Car: ![]() 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK.
Thanks for the advise....I drilled them out and replaced with nuts and bolts...thanks again!!
