overheat - sort of
the engine temp on my 93 rodeo 3.2L will go from normal range to just under the red marks, stay there maybe 20-30 seconds, and drop back to normal range. I assumed it was the thermostat and replaced it. no change. It's not loosing coolant. when it goes hot it will not blow hot air through the cabin heating system. Any suggestions?
Re: overheat - sort of
Have you done a radiator flush recently?
Do you have the original radiator? If so, it's probably in need of replacement due to internal corrosion.
1997 3.2L V6 Rodeo 32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack On it's way to 185k strong ![]() 2004 3.4L Tacoma TRD off-road 4x4 Double cab 32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
You May Have Air In The System
It's a replacement radiator, though not new. It appeared clean and in good shape. No corrosion or gunk in the bottom.
How do you de-air a coolant system? |
DO THIS WHEN ENGIN IS COOL
remove the upper hose from the pipes at the rear of the engine on the pass side remove radiator cap pour in coolant /water as needed untill it starts to pour out of the hose and pipe reinstall hose to pipe top off radiator start it up let it reach operating temp be sure radiator gets hot add coolant if needed should be good to go after that |
Did you recently replace the rad?
How old is your water pump?
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2 1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs 1996 VW Jetta GLS 2.0L 5 spd |
the proper way to de-air your coolant system is to crank the engine ( COLD ) and remove the radiator cap . the top radiator hoes just needs a little squezing. you want to see bubbles most people call it burping.but just to be safe have you checked all of your wires make sure their all good HOW long has this been going on
+1 for air pocket in the cooling system. Seen it many times.
sorry but your wrong on this one rizay it may work on an old 350 or some of the 4 cyl engines
doing what you are describing will not rid this system completly of air I am an isuzu tech and an confident in my description of getting the air out |
Well now you all got me confused, I've always aired it out as Rizay has described and have never had an issue. Did it this way on both Rodeo's without a problem.
may work but try the way i described its much less time consuming and all air will be gone no margin for error
why take a chance of overheating your vehicle and possibly cracking a head |
Hey, 2eyefish, is headgasket cracking common on these 3.2L's, specifically the 94-97yrs??
thanks //bc
1992 trooper 3.2L v6 sohc automatic...as is i love a good intermittent electrical challenge. . .especially when it's someone else's. |
It Is Not Common To Have Any Head Gasket Problems On These More Of A Head Problem When They Overheat
Yes Troop Heater Hoses
