Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 10-18-2006, 12:49 AM
Nashvegas Nashvegas is offline
Question B16A Reving & Heating up Need Help
Overheating & Revving Problem…among others.
Vehicle: 91 Civic Si with a JDM B16A engine swap.
  • When I start the car it will idle high and then oscillate up and down. Rep up then drop, rev up then drop.
  • It over heats. I replaced the thermostat, but even if im moving down the highway it over heats. What is strange is that its worse at nigh when its cooler than in the afternoon or evening when its hot. On several occasions I have turned off the ignitin and coasted while the temp dropped, and this did something once the car was running again...it remain hot for a moment then started to drop. This works now and again, but not at night when its cool.
Old 10-18-2006, 02:25 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: B16A Reving & Heating up Need Help
get a coolant flush...also check if your fans are working
this problem could be more serious than just the cooling system...when a car runs lean, it runs hotter than normal....the only reason i mention that is because of the weird oscillating idle you described. When that happened to me, i had a rather large vaccuum leak...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 10-18-2006, 04:43 PM
Gohan Ryu Gohan Ryu is offline
sounds like your idle control valve is failing. Here's an article on how to test/fix it:
http://www.findarticles.com/p/articl...04/ai_n8883803
Old 10-29-2006, 07:36 PM
riggitybizzang riggitybizzang is offline
It's a swap, so it probably won't run right without the correct maps. What air/fuel control are you using? If you don't have VAFC or Hondata or some kind of fuel management, im sure it won't run totally sound. Have you tinkered with the FPR?
Old 10-29-2006, 08:07 PM
MishaA's Avatar
MishaA MishaA is offline
If oscillating idle goes away after warm-up, it is most probably improperly filled or low coolant. Had this on two civics and pretty much sure in it. Take you time and fiil it properly, that might fix your overheating, too.
Old 11-18-2006, 06:36 PM
b18tegra b18tegra is offline
it could be ur sensor underneath ur intake manifold why its reving up and down
,and try keepin ur overflow box full all the time.
Old 12-02-2006, 06:33 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
but the reving is also accompanied by overheating. did you swap out the water pump when you swapped in the b16? hows the head gasket? comp test? leakdown test? oil leaks?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
