Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-17-2006, 11:59 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Engine Temp Problem
Hey all;
For the past couple months, I've noticed on my dash the engine temp gauge not working right. When I shut off the car, it used to go down to nothing. Now it stays where it was at when the car was on. It also no longer fully warms up. Normal temp was always half ways. Never gets there. Is this hooked up to the coolant temp?
I noticed this started happening after I over heated the engine once. According to the logger though, the coolant temp is fine. Anything I should be worried about here?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-18-2006, 12:12 AM
SLoe's Avatar
SLoe SLoe is offline
Re: Engine Temp Problem
Get a new gauge????
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 10-18-2006, 12:13 AM
david-b's Avatar
Dave is THAT guy
That's what I was thinking of doing. lol.
75 Monte Carlo
Old 10-18-2006, 12:16 AM
SLoe's Avatar
It's a good excuse for an aftermarket gauge anyway.
Old 10-18-2006, 12:20 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Does the gauge move at all or is just stuck on one place?
95 Talon TSI AWD
97 Eclipse GST
Old 10-18-2006, 07:32 AM
david-b's Avatar
Dave is THAT guy
It used to move a little. When I would turn on the car it would go down to the bottom and raise up to about a quarter. Now it moves about 1/4 to about 1/4 and a half. Very little movement.
75 Monte Carlo
Old 10-18-2006, 09:41 AM
I would guess either the gauge or the sending unit. It's most likely not a mechanical problem being as you said your logger shows it correctly.
95 Talon TSI AWD
97 Eclipse GST
Old 10-18-2006, 10:30 AM
david-b's Avatar
Dave is THAT guy
I'm thinking I'll just buy a new guage. Question, where do the sending units hook up to? Or can I tap the stocker?
75 Monte Carlo
Old 10-18-2006, 10:38 AM
david-b's Avatar
Dave is THAT guy
Also a stupid question, is that oil temp or coolant temp?
75 Monte Carlo
Old 10-18-2006, 11:11 AM
Killa's Avatar
Killa Killa is offline
My rs use to do that, I change the thermostat and it work find.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 10-18-2006, 01:35 PM
Coolant temp, and IIRC, you'll have to drill a new hole in the housing and screw the sending unit in there, I don't think you can tap the stocker, I guess it also depends on what kind of gauge you get.
You could also try getting a new/different cluster, but then your mileage won't be correct.
95 Talon TSI AWD
97 Eclipse GST
Old 10-18-2006, 01:37 PM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
does your logger show the coolant temp being low???
if so, try simply replacing the thermostat... it could be stuck open... also, check the wires going to the sender... they may be pinched or have come loose...
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
Old 10-18-2006, 02:04 PM
david-b's Avatar
Dave is THAT guy
Changing the cluster is easy. You can always "adjust" the mileage to what you have. I've rebuild 3 of these clusters already for myself and other people because something or other didn't work, like the odometer or trip or something.
I'm going to check all the wires and everything right now. And later when I goto work I'm going to pay close attention to the logger to see what it says. Last night it was saying about 180-190 I believe.
75 Monte Carlo
Old 10-18-2006, 02:11 PM
Mikelb's Avatar
wish you luck... keep us posted
Old 10-18-2006, 02:22 PM
david-b's Avatar
Dave is THAT guy
All the wires checked out fine. So when I goto work I'm going to check the logger.
75 Monte Carlo
