Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-17-2006, 10:00 PM
NorthChuckDrifter NorthChuckDrifter is offline
Brake Problem
Ok my front pass. side rotor is gone my outside pad fell off, and the brake pedal went to the floor. I replaced the rotor and pads and compressed the piston all the way down but the brake still doesn't respond. Whats the deal??
Old 10-17-2006, 11:39 PM
ricebike ricebike is offline
Re: Brake Problem
um did the piston fell out of the caliper bore????
if so, did you check for the square-cut seal inside of the caliper housing to see if it's there???
any brake fluid leaks???
i can't check it over the internetz
