| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
420a
sup ppl i was wondering is a 420A motor a interferance motor if the timming bet snaps or skips teeth will the valves bend or will it need a top head
Re: 420a
huh? rephrase the question.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Re: 420a
Is a 420A engine a interferance motor..like if the timing belts skips teeth will it bend valves
Re: 420a
yessssssss
1991 GSX 2.3 Stroker |
Re: 420a
i guess it depends on how many teeth it skips
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
Re: 420a
lol its just like any other motor that i know of... if the valves are open when the piston is TDC, it will bend the shit out of it...
Re: 420a
Knowing from experience, yeah, most likely. When my timing belt broke, it bent the intake valves and cracked a valve guide. Luckily it didn't mess the head up.
DSM's -- Turning normal, peaceloving mechanics into tool throwing, foul-mouthed alcoholics since 1990.
Re: 420a
There are motors that don't die because of a broken timing belt. An MR2 has an engine that is one of them. There are more engines out there than 4G63's and 420a's
He used the context correctly.
Re: 420a
Yes it's an interference engine (meaning that the valves and pistons overlap, but not at the same time) and if you skip too many teeth or break the timing belt, your valves will go bendy bendy. Just ask myself or Thor about how bending valves goes. If you've bent some valves, but not badly, you can just have them replaced without needing new guides or anything, but if you bent them very badly, you'll need new guides too. But in any case, you will not need a whole new/different head (although sometimes its cheaper).
And next time please use proper grammer. |
Re: 420a
Yeah, bending valves is fun! Almost as fun as throwing bearings. Fuck drugs, I can break engine parts! Ha ha...Yeah, I heard that the MR2 wont bend valves if the t belt skips/snaps but I never knew why. Learned something today other than what DNA is made of .
Re: 420a
Re: 420a
My belt decided to fail and my pistons knocked the valves off the head and imbedded them through the top of the piston.
Re: 420a
Re: 420a
my belt didn't snap it just skipped a few teeth so u guys still think i could have bent valves with a few teeth skipped?
Re: 420a
if it only skiped afew theeth its should be ok.
i always refer to it as a "free spining" motor the ford rangers and mazda pick ups i know are free spining motors
![]() 96 GS - 5 Speed-Sold 1998 Ford F-150 XLT 4X4 |
