Go Back   Automotive Forums Car Chat > Honda > Del Sol
Old 10-17-2006, 06:58 PM
Tyrone 95SolSi Tyrone 95SolSi is offline
Send a message via AIM to Tyrone 95SolSi
suspension
whats a good size (mm) for a rear sway bar? im not gonna race just want to start upgrading suspension and i see diffenert sizes. thanks
Old 10-17-2006, 08:19 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: suspension
Stock ones are around 13mm, this one is 19mm. Too thick and it can rip out the mounts from the chassis.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-18-2006, 11:13 AM
Re: suspension
http://cgi.ebay.com/ebaymotors/TEIN-...6197QQtcZphoto
thanks i didnt want to get one too big. this setup will work with my sol right?
Old 10-18-2006, 03:41 PM
NA is Best!
Re: suspension
Yup.
Old 10-18-2006, 05:17 PM
Re: suspension
would i need anything else?
Old 10-18-2006, 07:30 PM
NA is Best!
Re: suspension
Camber kit if you plan on lowering it and you want to do it the right way. Other wise, you'll end up with uneven tire wear. A bushing kit isn't a bad idea since you'll have most of the suspension apart. Check your trailing arm bushings as well. They are weak points and if they're shot, replace them.
