Go Back   Automotive Forums Car Chat > Subaru > Outback
Old 10-17-2006, 04:54 PM
9c3 9c3 is offline
Vents
1997 Outback
When I turn the heat on, the only the front dash vents blow air, regardless of what I selected. The windshield defog and floor vents don't work at all. Could the entire climate control module be bad?
Old 10-19-2006, 03:02 PM
Jay! Jay! is offline
Horizontally Opposed
Re: Vents
Is the switch mechanical? Which means, would it "thunk" into the different positions? And has it stopped doing that now?
Hierarchy of Subaru:
(Click to see mine!)
Old 10-19-2006, 05:03 PM
freakray freakray is offline
AF Modelrater
Re: Vents
Nope, it's not the entire module. There's a resistor block which controls the fans under the passenger side of the dash which has gone bad, if you pull it out you should be able to see the problem.
The block looks like an about 1" square of perforated metal with various wires and insulator inside and is a plug in - wish I had a photo to show you.
AF User Guidelines
Old 10-19-2006, 09:59 PM
9c3 9c3 is offline
Re: Vents
Are you talking about the blower motor resistor?
