Old 10-17-2006, 01:35 PM
TimL TimL is offline
Ignition switch replacement
I've got the symptoms of a faulty ignition switch on a '97 silverado. Can someone please tell me whether or not I will have to take it to the dealer to reprogram the computer if I replace it? The dash seems to lose power & it gives the codes P0740, P0785, P1860, then seems to be stuck in 3rd gear. I erase the codes & it's fine, for a while. Any help would be greatly appreciated.
Old 10-17-2006, 05:13 PM
2000CAYukon 2000CAYukon is offline
Re: Ignition switch replacement
No reprogramming should be required for an ignition switch replacment.
//2000CAYukon
Old 10-17-2006, 06:08 PM
777stickman 777stickman is offline
All of those codes are tranny related.
P0740=TCC Enable Solenoid Circuit Electrical.
P0785= 3-2 Shift Solenoid Circiut Electrical.
P1860=TCC PWM(Pulse Width Modulation) Solenoid Circuit Electrical.
1st most common thing in all 3 of these codes, besides the ign sw, is the TRANS fuse. It's located in the IP fuse block #20 10a. Don't check it just swap it out with a NEW one.
Try it and post back.........Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-18-2006, 12:13 AM
locknkey's Avatar
locknkey locknkey is offline
Its not an Ignition key switch issue, Problems would consist of not being able to turn ignition key smoothly in any position, stuck key, bent key (Could be cut to replace... or broken key, could be remove if no one has tried to remove it previously. IF it would not start and the thief light will blink, Fuel pumps shut down) to replace it will have to be programmed on-board with new switch and key, door/hatch locks could be rekeyed to match ignition key.
Sound like its going to be a transmission problem.
....And so thats just the way it is... (quote...me )
Old 10-18-2006, 12:39 AM
JaVeRo JaVeRo is offline
I had a 95 Suburban company truck that lost third gear. I could stop and kill the motor, crank it back up and everything worked fine. After doing this 4-5 times in two weeks I finally took it to the shop. It was the ignition switch.
James
Old 10-18-2006, 12:49 PM
locknkey,
The issue is not with the lock and tumbler/cylinder. The issue is with the ignition switch which is an electrical device. Here is a picture of the one for my truck (90 GMC K1500) http://198.208.187.182/internet/View...tNumber=D1405B
When this switch goes bad, it does not provide the correct voltage to the transmission and the transmission does not operate correctly.
This can be tested by checking the voltage at the transmission harness. This is also a fairly common problem.
//2000CAYukon
Old 10-18-2006, 03:08 PM
With the tranny codes always being in conjunction with the dash power problem, I took a leap of faith & picked up a switch, it's the whole harness. Of course I didn't have the inverted torx socket required, but found one today. I'm going to try it tonight, the new one is missing 2 wires that go to the ignition cylinder, that's kinda got me worried about security problems, but I'm not yet sure those two wires are truly part of the ignition switch. I will post back what I find, thanks for all the replies. BTW, I'm also replacing the #20 10A fuse.
Old 10-24-2006, 12:43 PM
The plug I was worried about actually had 3 wires, red/wht, orange/blk, and blue, and it did go into the big plug that is under the dash. I transferred it from the old harness to the new harness, and had no problem with security. I don't know if I had to or not, but I was afraid not to. On the big plug that goes under the dash, remove the blue clips on either end, then push the retaining clip down from the connection side with a small screwdriver, I used an eyeglass screwdriver, then just pull the wire out. The truck is running & shifting fine. Message boards are the greatest, maybe somebody will google this thread someday and be helped like I was. Thanks!
Old 10-24-2006, 05:55 PM
TimL: Great job and thanks for the post back.
57 Chevy 210
Old 12-31-2006, 08:14 PM
dpriceis dpriceis is offline
Hey I've got a 2000 with the same problems, How hard was it to change and how much? And did it fix it?
Thanks,
