I have a strange problem that I can not figure out! I have a 1994 Z28 with the LT1 engine. Recently I changed the thermostat and radiator cap out. Now I have an invisible leak! The car will start and run cool as hell! About 190 but driving down the road the low coolant light will come on. I shut off the car and restart it goes off. But here is the weird part, the water is low! What could cuase the water to be low? There is no leak! Water goes into the resivoir, could it be that it is not being sucked back into the radiantor? How woul dI check this?
Re: Lt1 Z28
You still may have a leak at the thermostat housing that gets burned off by the engine heat so you don't see it. You should still smell the antifreeze though.
Have the cooling system pressure checked, that's the only way to find your elusive leak. Bob |
Re: Lt1 Z28
I have that sucker run while crawlin around like a snake under, over and in it! And the amount of water that is missing is about 2-3 cups! So I would see that! But then again some is blowing out thry the overflow!
Re: Lt1 Z28
Did you open the bleeder screws when you put in the coolant cause if not you are creating very dangerous hot spots in the cylinder head and thats the reason for the level declining.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Re: Lt1 Z28
blown head gasket? (worst case scenario?)
Car: ![]() 1997 M6 SS Camaro [ white ] 285's in the back all else = STOCK.
Re: Lt1 Z28
I would doubt a head gasket leak. It should be showing up in the exhaust or oil if it was blown.
I was diagnosing a car with an elusive coolant loss years back, we wound up removing one spark plug at a time, starting up the engine and watching the plug hole until we came to the one that blew out steam. I think that you'd be best off doing a static pressure test. If that turns us negative, get some Solder Seal Block Saver and put that into the radiator. If you did have a minor internal leak, this will take care of it most of the time. Bob |
Re: Lt1 Z28
Thanx I will try that! But I did find that the overflow has a small pin hole up at the full hot line so that could a part of it!
Re: Lt1 Z28
Ummmm,
If I may, and not to sound like a smart-tart, I read the word water a handful of times in this thread. So, um, what did you put in it after you replaced the stat and cap? |
Re: Lt1 Z28
ya, never run water in your car, water+metal=rust! And water can freez and boil so just uses antifreeze.
95 Z71 Silverado 4x4 ext. cab Mods- Flowmaster Exhaust,Intake |
Re: Lt1 Z28
this is for the 2 kids that keep correcting me! Water is a "term" not what is in the car! If you have no advice to give please say nothing you are wasting time! Mine and yours! Go find something to do! For those of you with the advice well taken and I will look it to that!
Re: Lt1 Z28
Whoa, easy there, I did state not to sound wise. I merely asked, just to be sure it was not purely water in the vehicle.
This "kid" happens to be a forum moderator asking you a simple question and thus if it were determined that the answer was it was just water, that would solve alot of troubleshooting and to the contrary of your hasty repsone, save folks alot of time, vs wasting it. I was not "correcting' you, again, merely verifying. It has happened before, the exact same problem. a few days later it was finally pointed out that the car did in fact have staright water in it. So it's not to offend you, but again, to cover the basics and help us help you. So on that note, welcome to AF as I see you just recently joined. However, if you want good advice, you need to slow down a bit and take into account we don't know the condition of your car, or the extenet of ability and resources you may or may not have. Please check your PM box in the User CP Last edited by wrightz28; 10-18-2006 at 02:04 PM. |
Re: Lt1 Z28
Re: Lt1 Z28
As you wish. Goodbye aswell.
Re: Lt1 Z28
Soooooo.. how about those Mets?
