Old 10-17-2006, 07:40 AM
ropergilson ropergilson is offline
replacing water pump on 85 305
My water pump blew on a long trip and I had to have my tuck towed (coolant pouring out of it) The shop I took it to is one I have done business with before, they havent ripped me off. They looked at it and quoted me $475 to replace the pump. Is this something I can do myself? I see its on the front of the engine and has the fan attached to it. how big of a job is this? I have a little experiece with auto repair. I see that I can get the pump for about $40 at Advance Auto, the machanic mentioned its mostly the labor cost on this job.
Old 10-17-2006, 08:48 AM
idmetro idmetro is offline
Re: replacing water pump on 85 305
ropergilson;
I assume your 305 is basically the same as my 86 350 and yes this is a job you can do yourself. Just be prepared to pull (or at least loosen) most everything you see on the front of the engine to gain access to the pump. Give yourself plenty of time, when you remove bolts put them in a ziplock and label them with a marker so you'll know where they go back to. Take some digital pictures before you start so you'll have a reference if you need it later. Change belts while you have the system apart. Good luck!
Old 11-04-2006, 09:42 AM
Elbert Elbert is offline
$475 is too much. Yes you can do this yourself. you need common hand tools (mechanic) a couple gallons of coolant, new water pump and gaskets, and maybe some "fast-tack" (its a red liquid you can use to coat the gaskets) whick makes the install a lot eaiser.
Round up a buddy to help...if you've never done this before.
Old 11-04-2006, 10:48 AM
alblogg's Avatar
alblogg alblogg is offline
Man $475 to put on a water pump must have something to do with having to handle that hazardous green stuff in the radiator or something. Like he said take your time I think you will be all right and if you run into trouble someone here will lend a helping hand.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 11-05-2006, 04:19 PM
454Chevy 454Chevy is offline
to do this you will have to drane the radiator and take the fan shroud off (about 4 bolts) the fan (4 bolts) the pulley will come off with the fan. loosen the alternator ( 1 bolt on top of braket) you will have to take off the lower alternator braket off (2 bolts bolted on the water pump ) you take off the lower water hose now you unbolt the water pump ( 4 bolts ) before you put on the new water pump you will have to clean the surfes of the engine block where the old gaskets where so you wont have any water leaks
Old 11-06-2006, 12:16 PM
glenncof glenncof is offline
I've replaced my 1997 5.7l (350 ci) a couple times. The key things I remember/suggest is:
1) Carefully look at serpentine drive belt so you can reinstall. There should be a diagram under hood. 3/8" breaker bar to remove tensioner tension.
2) The fan/drive needs to be removed. I think I used a large adjustable and a rubber strap wrench (to hold the pulley). Careful when reinstalling not to cross tread.
3) Clean mating surfaces completely. I used single edge razor blade and/or exato knife. I put Permatex Water Pump gasket compound on gasket, pump side only.
4) I used the four bolts to hold gaskets in place while installing. This was the tricky part as gaskets tend to slide around. Keep pulley off while doing this to minimize weight and make it easier to hold/position pump with single hand.
Old 11-06-2006, 01:58 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
475 is a total ripoff and without lube,
they saw you coming man
you can do this, this is vertually the easiest water pump to replace in the world other than maybe on a straight six engine and a very few car models
remove fan, pullies and alternator and top bracket, and bolts on left side of power steering pump and just loosen up the bracket on right side of power steering pump at the exhaust manifold enough to move it a little ways away from the waterpump
bottom radiator hose and the four bolts that hold the pump the engine block
done
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 11-06-2006, 03:52 PM
jveik jveik is offline
yeah definately not worth 475 bucks. you can do it on a saturday afternoon in your driveway and just spend about 75 bucks maybe on the waterpump. just hose off the antifreeze that falls on the driveway cause it will dogs or other animals that drink it, including humans (duh...)
