Old 10-17-2006, 07:07 AM
wilo wilo is offline
Broken Airbrush PLEASE HELP :-(
Right last night while spraying some parts for my SLR i somehow managed to stab myself big time in the finger with my airbrush with the tip off, while cleaning it not only did it hurt like hell (still VERY SORE now) but after noticed that the fluid nozzle had broken see pics below.
Fluid Nozzle
Airbrush
Airbrush
The thread is still in the airbrush can this be fixed and if so does anyone know anyone in the UK that could fix it.
It is a Iwata HP-C
GUTTED
Old 10-17-2006, 10:58 AM
Re: Broken Airbrush PLEASE HELP :-(
Bump
also if totalled any one know of a good UK suppier for Iwata so i can pick a new one up?
Cheers
Old 10-17-2006, 01:33 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Can't really help you diagnose it from the pics- unfortunately the important parts to see are out of focus. It's possible you damaged just the nozzle, and if so it can be replaced (would probably cost about 1/4 the price of a new airbrush). It's also possible the damage is more extensive than that, in which case it's time for a new airbrush.
Any chance of better pics?
PHOTOBUCKET SUCKS
Old 10-17-2006, 04:07 PM
mavk mavk is offline
I got this problem four weeks before.
The thread of the noozle broken off. I contacted the dealer and he sends me a new noozle. It was a bit tricky to get the broken off thread out of the gun, I used tools from the dentist . I screw in the new noozle and it works perfectly.
Old 10-17-2006, 05:12 PM
hi mpwr yes sorry about the poor pictures the top picture is the fluid nozzle which has snapped off and left most of the thread in the airbrush with no way (that i can see) of getting the thread out of there.
i have tryed superglueing some metal rod inside and turning it out with no look it seems to be in there tight.
Old 10-17-2006, 06:54 PM
cyberkid's Avatar
cyberkid cyberkid is offline
I was thinking a few ways of fixing this~
You could find a small screw that fits inside the broken part, then screw it in and using pliers pull on the screw and unscrew it slowly.
Another way would be to find a metel rod the same diameter as the ab's needle, brass or copper might work best as they are softer metals, shape the end into a needle point and insert the rod as you would the AB's own needle. then pushing firmly turn the rod clockwise.
Hth,
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 10-17-2006, 08:31 PM
MPWR's Avatar
So basically nozzle broke off from the airbrush, leaving its male threaded portion left in the airbrush? Yeah, that will be kinda tricky to remove. But it can be done with the right tool. I'm thinking a small screw extractor or a small T handle reamer may do the trick. (Superglue won't do anything for you. There's no way it is strong enough to grip the broken section- hopefully it didn't get into the threads, in which case you've made your work harder.)
These are reamers- you just insert the tip and twist (to the left). Hopefully it would grip the broken section and twist it out.
These are screw extractors. If you find one small enough to fit, you just screw it in (also left handed) to the broken off part. It will grip, and you continue turning it out.
Hope this helps....
PHOTOBUCKET SUCKS
Old 10-18-2006, 04:24 AM
Hope this helps....
Cheers all
i will try these suggesions asap
Thanks again
