Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-16-2006, 11:39 PM
trey252 trey252 is offline
alternator
if a alt. is no good will the car start. I have a 98 camry 4 cyl. I was going to put on a water pump. I took off the battery cable, but put back on for something I had to do. I think that I hit the alt. with the hot wire and it sparked. could that have caused the car not to start.
Old 10-16-2006, 11:45 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: alternator
You can remove the alternator and the car will start. The only job the alternator has is to keep the battery charged. The car should start but will only run as long as the charge on the battery will sustain enough voltage to fire the plugs, run the computers, etc. I'm guessing that would be 15 minutes or so.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-17-2006, 12:45 PM
somick's Avatar
somick somick is offline
Re: alternator
It sounds like you shorted one of circuits.
Have you checked ALL fuses?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
