Old 10-16-2006, 11:26 PM
Jergin01's Avatar
Jergin01 Jergin01 is offline
Question what is the problem?
I brought my car to a mechanic who usually fixes all of my problems, but not this time. He replaces a pitman arm and said my tire was rubbing. Yeah, right. My Blazer is riding so rough that its annoying me now. Here is a list of the problems:
-The front passenger side wheel squeaks while driving straight at low speeds (less than 20mph). It stops making noise if you step on the brakes, turn the wheel to the right-hand side, or turn the music up.
-If you are driving straight, no matter what speed, and turn the wheel anything more than three inches to the left, and there is a grinding noise which sounds like it is coming from the driver side wheel. The grinding noise gets a lot louder at 70+mph.
-When your going down an incline and turn to the left side, something sounds like metal whacking metal one time. This doesn't happen if you have the brakes pressed.
What do I have to do to fix all of this? What parts am I looking at?
2000 S-10 Blazer LT 4.3L EFI 4DR 4WD
Alpine CDA-9835 Headunit w/ iPod
Custom Wheels w/ Toyo 255/40/20
Custom Exhaust - 3" Chrome Outlet
All Clear Lights w/ L.E.D Bulbs
Silver Interior w/ Brushed Aluminum Trim Pieces
Check out my Blazer on CarDomain.com
http://www.cardomain.com/ride/856449
Old 10-17-2006, 04:31 PM
old_master's Avatar
Advisor/Moderator
Re: what is the problem?
The brake pads have a warning sensor and it is designed to make a squeaking sound when it contacts the rotor indicating the pads are worn out and in need of replacement. Remove the front wheels and check the pad wear, replace them if necessary.
The grinding noise while turning may be a worn wheel bearing. To inspect the hub/bearing assemblies, the wheel must be installed on the vehicle and off of the ground. Grasp the wheel with one hand at the 12 o'clock position and your other hand at the 6 o'clock position. Rock the top of the wheel in and out and watch/feel for any movement. There should not be any noticeable movement, if there is; the hub/bearing needs replacement. There are two sets of bearings in each hub, one inner and one outer. While driving, turning the steering wheel to the left will load the right outer and left inner bearings. Turning the steering wheel to the right loads the left outer and right inner bearings. Determine which side the noise is emanating from and you've found your worn bearing/hub. The bearings are serviced by hub replacement only.
Old 10-17-2006, 05:12 PM
Jergin01's Avatar
Now how much do you think this will run me? And do you think it will make my ride a lot better?
Old 10-17-2006, 05:35 PM
old_master's Avatar
Advisor/Moderator
Repair costs vary depending on your location. Brake pads and wheel bearings will not affect ride quality. If they are in need of replacement and are replaced, the noises should go away.
Old 10-17-2006, 10:16 PM
Jergin01's Avatar
So then what should I replace to make the ride better? Shocks...? When I bought the car it rode so nice, but the ride seems like its getting progressivly worse.
Old 10-17-2006, 10:56 PM
ricebike ricebike is offline
bring your car to a different mechanic~2nd opinion
Old 10-28-2006, 06:06 PM
Jergin01's Avatar
Smile Re: what is the problem? (RESOVLED)
Well you drilled it, turned out to be a mess of problems but the main one was the wheel bearing. Hub needed to be replaced like you said ($457 w/ labor). The other issue was the brakes. Since the bearing was broken it wore the brakes 90% on one side and 75% on the other. WOW! Then the brake fluid was disgusting. It came out to be a chunk of change but at least it rides like new.
Old 10-28-2006, 06:48 PM
old_master's Avatar
Advisor/Moderator
Glad you're back in business.
