Old 10-16-2006, 11:05 PM
wannabelow wannabelow is offline
98 chevy help
this is going to be long
i have a 98 chevy 1500 5.7 vortec i broke a conecting rod back in july, so i droped in a gmcreate motor from cmp and now the thing is just a huge headach i was getting p0303 p0300 p0171 i think it was the 171? means lean on bank1 (if not lean on bank 1 is the code i am getting) so heres the fun part new dis,cap,rotor,wires,plugs,coil, all replaced with gm spec ones fiddled around with it and now i am only getting p0307 witch is miss fire on 7 but every thig is new put a timeing light on it and its way off allaround but when u change it to line up with the timeing marks it wount even start everone i have talked 2 say to check my cmp retard but i dont have acces to a scan tool.
any ideas on this new exaust,distubtor,cap,rotor,wires,plugs,coil. plugs are gaped to 0.060in i think thatz the spec the hainse manule saysif its not it it dont the the specs in the book.
some one has asked me about a after market cam in the create motor it is the stock cam as i got the replacement one from gm for the truckas for the old one i dont know but if they is a way to check wioth out ripping the motor apart please let me know.
dose my comp need to be reprogramed? could it be the thing beside the coil on the bracket i cant rember the name of it? or any one with a scantool that could help me out i am in calgary?
thanks
Old 10-17-2006, 12:00 AM
Re: 98 chevy help
i also forgot to say that when in park it idles fuine but in drive it stalls out 4l60e trany and i kniow its not the trany as i drove it to where it sits right now and got it back from the trany shop about 4 weeks ago and this is the frist time it has moved since
Old 10-17-2006, 12:27 AM
2000CAYukon 2000CAYukon is offline
Re: 98 chevy help
Reprogramming could be needed depending on the cam and headwork but they should have told you that when you bought the engine.
Have you checked the fuel pressure? Low pressure can make you run lean.
Remember that a miss can be a fuel injector not firing OR the spark not firing. Double check all of the fuel injector connectors. It is easy to cross one up.
There is no way to set the timing on the Vortec. You need to set the cam retard and that can only be done with a scanner.
//2000CAYukon
Old 10-17-2006, 12:33 AM
Re: 98 chevy help
200cayoukon u have pm
Old 10-17-2006, 09:09 AM
Re: 98 chevy help
is there a way to tell where the injoctors go and the order? if they were messed up shouldint it still be giveing me a p0300 code and not just a p0307?
Old 10-17-2006, 10:27 AM
texasboy05's Avatar
texasboy05 texasboy05 is offline
Re: 98 chevy help
if u take care of the timing issue and still have a mis, run a bottle of seafoam through ur system and it should clear it all up. i had a similar problem n replaced damn near everything and still had a mis n that cleared it right up. u could also have a mis if ur cam position sensor is goin out.
Old 10-17-2006, 10:52 AM
Re: 98 chevy help
how much is the sensor as thtas th onely thing i havent changed
but woulduing that through a p1345?
Old 10-17-2006, 07:14 PM
Re: 98 chevy help
Old 10-17-2006, 09:03 PM
Re: 98 chevy help
Why replace a sensor when you are getting a misfire on 7?
Were you able to get the cam retard set with a scan tool?
If it is easy to get at the injectors, you could swap 7 and 5 to see if the problem follows the injector. If the problem stays with 7, then you should verify the injector is firing with a injector test light.
You should also check to be sure the plug wire for 7 is in good shape. Try routing 7 so that it is not parallel to 5.
//2000CAYukon
Old 10-17-2006, 09:23 PM
Re: 98 chevy help
i dont have a scan tool i just have a code reader the injctors are kind east to get 2 but a pain in the ass cus i gota pull the upper intank manifold off
Old 10-23-2006, 04:53 PM
Re: 98 chevy help
ok my uncle played around with it the other day and now the only code is p1345 crank cam sensor do i still need a scan tool or is there any way to get it with out a scan tool
Old 10-23-2006, 06:13 PM
777stickman 777stickman is offline
Re: 98 chevy help
YES!! you still need a scan tool (for the 3rd or 4th time) & NO!! you can't time it without it. The CMP (cam postion sensor) is in the dist which runs off the cam. P1345 is most likley caused by the dist being 1 or 2 teeth off in either direction of were it should be. Once it's in the right position you WILL need a scan tool that you can put in the "cam retard" or "cam offset" mode to set the timing at 0 +/- 1 or 2 degs.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-26-2006, 10:01 PM
Re: 98 chevy help
update
had some one with a scan tool come over and found mutply missfires did a ompression test and found it to be low adjusted the valves and didnt set the cam retared cuz of a leaking dis gasket so i put a new one in and droped the dis back in where it was in the exact same spotand now the p1345 is gone and p0300 is back he is comeing back to set the cmp for me would this fix the p0300 code as it is not a p1345 anymore?
