Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 08-28-2001, 09:12 AM
TeamNissan TeamNissan is offline
Send a message via ICQ to TeamNissan Send a message via MSN to TeamNissan
Camshaft and Injection
HELP
I NEEEEEED some racing camshafts and some new injection jets......
Can anybody give me some information on how to find that!!!??
NISSAN RULES...........
http://www.nissanklubben.dk
Old 08-28-2001, 09:29 AM
Anthony Anthony is offline
Why do you need new injectors - are you planning on turbo'ing your motor? The stock 259cc injectors will cope with pretty much anything non-forced induction I would have though.
If you do need new ones, then you can get some 370cc ones from a 200SX SR20DET, and these will connect to your existing fuel rail as well I believe.
I *think* you'll have to get the ECU remapped for the new injectors though - something like a Unichip will do the job.
Owner of Primeraweb, and a 1997 Nissan Primera SRi driver
Old 08-28-2001, 09:51 AM
HELLO Anthony....
aaaaaaaaaaaaaahhhh I just read your signature, and it appeared to me that my car is on your homepage.... :o)
Well anyway i have spoke to the Danish Nissan Guru and he told me that he could chip my car and combined with new injectors and maybe a couple of new camshafts he could get about 170-180HP (7.800rpm) out of my engine..... I'd like that.... he he
Old 08-28-2001, 10:00 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
I assume that's crank hp. If you're getting 170-180 at the wheels you'll need at least 370cc injectors. The DET ones are just a plug in like Anthony said. And you will need your ECU remapped or some other way to change the pulse width.
If you're talking about 170-180 at the crank you don't need new injetors the stockers are just fine.
You're going to need some higher compression and some very hot cams to get 170+hp at the wheels.
Old 08-28-2001, 10:21 AM
Hey G-Force
Thanx for the input......
I will enlight him with yours and Anthonys input and then I will get back to you tomorrow with some more details!
Old 08-28-2001, 02:47 PM
P10DET's Avatar
P10DET P10DET is offline
To add 25-35 hp, you will probably need:
Header (extractor)
Remapped ECU
Cold Air Intake (filter in the fender well)
Good cams
You won't need different injectors.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 08-30-2001, 03:25 AM
Tuning
He says I need
New ECU
New cams 280-285 dg cams
New injectors
It should work.....
Old 08-30-2001, 03:52 AM
P11GT's Avatar
P11GT P11GT is offline
Send a message via AIM to P11GT Send a message via Yahoo to P11GT
Hey gurpal, you got mail!
anyway, ive got some fast road cams in and a unichip, but havent had the chip remapped for the cams just yet. There is a noticable difference at the bottom and mid range, but i was a little dissapointed, i was expecting more. Anyway, i might also look into new injectors, see what the tuning companies say around here. One of the problems are my filter, i think. It currently sits behind the battery and doesnt have a cold air feed. I might look into extending the pipe to relocate the filter in a cooler part of the engine bay, cos at the moment, it seems to be sucking up warm air.
I'll ask around, see what i find out about the injectors and let you know.
Old 08-30-2001, 04:10 AM
P11GT's Avatar
i just rang a company here in the UK called Norris Design, they say i will only need the injectors if im having fueling problems with the new cams, but until i get it remapped, i dont know, aaaaahhhhhh vicious cirle kinda thing going on. The stock injectors should be able to handle a bit more horse so i dont think i'll need them. They have a set of 4, second hand which will cost me £100 inc. postage
Old 08-30-2001, 05:05 AM
ragt20's Avatar
ragt20 ragt20 is offline
Send a message via AIM to ragt20
yep got the mail....thanx....
ps have you tried cold air feed like I have for my K&N,,,,,,,,
:flash: :flash:
Old 08-30-2001, 05:34 AM
Your standard injectors should handle up to 170HP
But try remapping your ECU then you will get much more out of your cams.....
Old 08-30-2001, 08:22 AM
P11GT's Avatar
im gonna try getting a pipe bent to go further around and below in the engine bay to mount the flter on, to get cold air, but not too low, dont wanna hydraulic the engine. I'll have a proper look when the weathers a bit nicer here.
Old 08-30-2001, 08:43 AM
P10DET's Avatar
Re: Tuning
Originally posted by TeamNissan
He says I need
New ECU
New injectors
It should work.....
You absolutely do not need new injectors. We have someone here in The States putting 170 hp to the wheels with the stock 259cc injectors. He has not run out of injector either. This is verified by JWT since they he has been doing cam testing for them.
Also, you will not gain 25-25 hp from cams and a ECU remap, although 20 is on the fringe of what is possible. There is no way for you to make 170 bhp (roughly 145 to the wheels) without a header (extractor). Chances are you will need a true cold air intake as well, not just a tube running cold air to the filter.
George Roffe
Houston, Texas USA
00 328i
Old 08-30-2001, 08:55 AM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Thumbs up
Go for the Cold Air Intake!!!
...actually the cold air effect is minimal. The added horsepower is actually from the intake being longer and funnelling the air in at a higher speed.
Old 08-30-2001, 09:53 AM
P11GT's Avatar
boogie...... where is your filter located then? i see that the pipe goes down into the hole where the resevior would normally be. The main problem is that there isnt anywhere in the UK that sells the CAI and its a pian the ship over. How much am i looking at anyway?
I should be able to get the same diameter piping to extend it, would this has the same funnelling effect? or does it need to be at different diameters ie smaller at the filter and bigger at the intake manifold, or vice verser?
