Old 10-16-2006, 10:27 PM
teb880 teb880 is offline
No Heat!!!!!!
I have a 98 jeep with no heat motor is warm and engin runs at normal temp, replaced the rad 2 months ago, after that have had no heat not sure if they are related anyone have any Ideas????
Thanks
Old 10-16-2006, 10:28 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: No Heat!!!!!!
what do you mean "no heat"?
do you mean the engine temp gauge isn't reading anything?
do you mean it's actually cold?
do you mean there's no heating through the air vents?
Seatbelts Saved My Life
Old 10-17-2006, 06:31 PM
Re: No Heat!!!!!!
no heat through the vents..
Old 10-17-2006, 06:49 PM
Re: No Heat!!!!!!
depend how your heating system works. if you have a heating element seperate from the engine (like an electric heater system) then that's probably what's at fault.
check the fuses, and if you can't find anything wrong, take it to be looked at by a professional.
Old 10-18-2006, 07:56 AM
jveik jveik is offline
Re: No Heat!!!!!!
does it use hot engine coolant in a heater core on the firewall? if so, then they likely messed something up when they were putting in the new radiator lol though i dont remember exactly how it's usually hooked up or how it works
