Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 10-16-2006, 08:58 PM
mab6680 mab6680 is offline
noise from wheel well
i have a 2000 xls 4wd 4.0 ohv i repaced the rack and tie rod ends about a year ago and just replaced all of the ball joints and end links last weekend when i was done and took it for a test ride there is a rattle and a thump in the front passenger side wheel well so i took it back home and checked it out and found a bad tie rod so i changed the tie rod now the thump is gone but the rattle is still there it only happens at slow speeds when i drive on uneven ashphalt i cant find any thing wrong with the fron end nothing loose any help would be great thank you
Old 10-18-2006, 10:08 AM
xthirdimpact xthirdimpact is offline
Re: noise from wheel well
HOLY RUN-ON SENTENCE, BATMAN!!!!! Punctuation marks are our friends! Try it sometime!
Have you replaced the front shock absorbers? I got thumps and thuds before and replaced them with new Ranchos,....problem solved.
Why did you have to replace the rack?
Old 10-19-2006, 04:15 PM
replaced with KYB shocks about a mounth ago
Old 10-21-2006, 09:54 PM
jeepers robin!!! Found out the problem it turned out it was the wheel bearing. I was a bit confused because there was no vibration at all. Oh i had to changed the rack because it was slowly leaking fluid into the tir rod boot on the pasenger side. Hope that was a little better for you not the best with the whole Punctuation thing. P.S. thanks for the help.
