Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 10-16-2006, 07:30 PM
sweetthing sweetthing is offline
Unhappy spark plug blowed out
2002 Exp. number 2 plug blowed in two pieces replaced still runs the same idles rough an what to do next HELP me please repair place is having a field day with me.
Old 10-16-2006, 08:30 PM
rhandwor rhandwor is offline
Re: spark plug blowed out
If you have a 5.4 liter engine you may have damaged the coil. Pull it out and put a spark plug in it ground the plug. Check for spark if it bothers you to do this buy a spark tester a plug with a clamp on it. Then check for spark. If you have spark plug wires ohm them. You probably need a tune up.
Old 10-19-2006, 09:12 PM
bearcat329 bearcat329 is offline
Angry Re: spark plug blowed out
my #2 plug blew out monday morning, still checking the damage, have'nt tried to do anything yet, waiting to hear back from a friend/ mechanic i know
and it did break the coil into a few pieces
good luck with yours
Rick, Ore
Old 10-21-2006, 01:18 PM
Hope you all have better luck than me I finally found someone that know what they where doing ,when the spark plug blow pieces of it worked its way down the head an cracked my block so now i need a new motor .
C C
Old 10-21-2006, 02:35 PM
While its possible to crack the block it is more probable that you cracked the head. I assumed when you changed the plug you got all pieces sometimes you need to use a small magnet. Was a head pulled to verify damage of the engine if this isn't done you don't know. Also a piece of metal on top of the piston will make a racket letting you know to shut it down.
Verify before signing a work order for a new engine. Make them show you the damage before you get taken to the cleaners.
Old 11-12-2006, 12:03 PM
Thumbs up Re: spark plug blowed out
ok, i'm back on the road! well after 480$ later i am, found a shop that's dealt with the problem before, they have speceal tools for this , a re-threader that inserts and cuts the threads from the inside out was the 1st attempt to fix, no luck there, then a reamer and a insert ( heli-coil ) to replace the threads worked, labour alone was 350$ new coil was 97$ insert was around 6$, avoiding going to the dealer?? PRICELESS!
Rick, Ore
Old 03-06-2007, 07:16 AM
jsinton jsinton is offline
Exclamation Re: spark plug blowed out
I was reading on the internet where big block Fords have this problem where there is not enough threads to hold the spark plug in the aluminium head, and people were blowing out the spark plug. Rumors of a recall, but Ford is fighting it because it's too many vehicles, and it would bankrupt the company. It would take replacing the heads on all those trucks. Some people have replaced the heads on their trucks two times.
