Old 10-16-2006, 03:51 PM
1987ss's Avatar
1987ss 1987ss is offline
94 non responsive
after driving for a half hour when you step on gas it dosent respond, but if you gradualy push accelarator little buy little it will pick up some speed. it acts the same in netural drive or park.. it does not stall eithor i dont know were to start... no ses light oe check engine.. Thanks
also if you park it for 15 min it will go back to driving normal then
Old 10-16-2006, 07:07 PM
rhandwor rhandwor is offline
Re: 94 non responsive
I would check the fuel and air filter first. Does it act like lack of fuel or is their a definate miss.
Old 10-16-2006, 09:54 PM
Ken Naw Ken Naw is offline
Had similair problem last week. Changed Fuel filter, plugs, wires, cap and rotor. Problem gone. (fingers crossed)
Let us know what you find.
Thanks
Old 10-16-2006, 10:09 PM
1987ss's Avatar
its more like a lack of fuel... it hesitates realy bad when it acts up.. just tonight it started acting up i held the pedal down in park the rpms didnt go up it did a slight back fire and continued to hesitate on accelerating.. i shut it off turned it back on and it was fine... i dont know were to start
Old 10-16-2006, 10:10 PM
1987ss's Avatar
Thanks
i will tomarrow
Old 10-19-2006, 01:52 AM
1987ss's Avatar
havent gave it a tune up but took off dog house and drove around with scanner and fuel press tester hooked up for 2 days and no problems yet it is frustrating me!!
Old 10-19-2006, 07:52 AM
Check the pressure regulator it is close to the fuel rail pull the vacuum hose if you find gas replace it. You can use channel locks and pinch off the return line at a rubber hose. If this helps replace the pressure regulator. Normally the pumps comes up to pressure and the regulator when it gets vacuum returns to much fuel to the tank.
Once gas is ruled out then start with electrical.
Old 10-20-2006, 06:35 AM
dewaynep dewaynep is offline
This is just a shot in the dark, but you said you drove it with the doghouse off for 2 days and didn't have any problems. Is it possible the plug wires are routed in such a way to get smashed by the doghouse to cause arcing? Also, is the coil wire routed correctly so when the doghouse goes back on it doesn't contact the foil covered heat shield around the inside of the doghouse? If you can drive it without the doghouse on and it runs fine, then I would suspect this is the problem.
Old 10-30-2006, 10:29 PM
1987ss's Avatar
to day it acted up again this time it stalled had to let it sit for a min and it restarted.. but stalled out a few more times and restarted.. i did how ever do a complete tune up a week ago as well... today i heard the fuel pump run for a second a pause and run again pause and run again .. that was when i had the key in on position with out rotating the engine.. normaly it runs constant for 3-5 seconds with out the pause.. and im gonna check wire routing in am thank you
Old 10-30-2006, 10:34 PM
1987ss's Avatar
is it the same with the cmfi?
Old 10-31-2006, 07:45 AM
I would check the grounds for being tight and clean. Above left wheel house,rear of engine,front of engine, left side of engine below coil. A loose ground will cause a pump or relay to sometimes work or not work.
Yes a bad fuel pressure regulator will cause starting problems. Normally when you pull the vacuum hose they will leak but not always. The best way is to check with a pressure gage.
If you heard the pump start and shut off start with grounds. Then check the fuel pump relay next check for a loose wire.
Old 11-02-2006, 11:54 PM
1987ss's Avatar
i can not find fuel pressure regulator. i have a cmfi engine if some one could tell me were it is it would be appreciated.. i put dioelectric grease under igition module that is under cap and on plugs coming from coil to distributor. and it still is acting up.. it also back fires in the in take when you wot it when it is acting up..
Old 11-03-2006, 07:03 AM
brcidd's Avatar
brcidd brcidd is offline
My '94 Astro CMPFI did the same- took me several tries to figure out that the wire going to the top of the spider (CMPFI) assembly was intermittent- had a thin broken spot- I had replaced 2 spider assemblies (mega bucks) before I finally got to the bottom of it- once I replace the wiring harness that plugs into the top of the unit- all was fine. I got really good at removing the upper intake plenum- I think I had it off 11 times in 2 yrs.. Van was towed home at least 4 times- and it usually would start when unhooked from the tow truck- I had even made my own connector for the top of the spider- that worked for a few weeks until it bit me again....The wiring harness was $87 which I thought was excessive- so I found a used one from another Astro....
Old 11-03-2006, 07:08 AM
If you have throttle body injection with two injectors on top chevy's regulator is on the back of the body. You can feel it if you put your hand under the back edge. The parts store should have rebuild kits and a gasket set if you want to also clean it. Otherwise it is on the fuel rail for the injectors.
Old 11-03-2006, 10:13 PM
1987ss's Avatar
they changed spider before i purchsed it! how can i tell if that wire is broken? does intake have to come apart?
