Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-16-2006, 03:51 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Coolant problem!!!
When I drive my coolant gets flushed out of my system and into my overflow bottle where it then gets sprayed out the overflow hose. The system won't keep any coolant in it. After I fill it up it will stay in there for about 2 days or so untill it drains itself. I have replaced the thermostat and the radiator cap. I do suspect that my head is cracked/warped but, would this make the coolant flush into the overflow bottle? Could my radiator or something else in the coolant system be clogged up or very dirty?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 10-16-2006, 04:06 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Coolant problem!!!
Is the coolant still that vibrant green color?
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-16-2006, 04:41 PM
NateS's Avatar
Yes, the coolant is still the same color as when I put it in.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 10-24-2006, 11:38 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
What kind of radiator cap did u put on it. I had this problem with a few cars that ive worked on in the past and it ended up being the radiator cap, eventhough it had just been replaced recently. If the oil looks good with no coolant and vice versa i wouldnt think itd be the head gasket. Im pretty sure they are 13psi radiator caps for the cooling system. Is it possible you could have gotten one rated at a different psi than your cooling system? Like i said ive seen the exact same problem in a couple other vehicles and thats what it ended up needing. If so it could also be possible that the thermostat was put in backwards too but often isnt the case.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 10-24-2006, 11:42 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Does the car run at its normal operating temp when it runs?
95 Talon TSI AWD
97 Eclipse GST
