Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-16-2006, 01:31 PM
DSMNerd6889 DSMNerd6889 is offline
Need help working kinks out of the GSX
Okay guys... had a few problems with the GSX, but they were expected, the car has been sitting for two years. Problem number one: the car idles fine, and if I go wot, it seems to rev fine, but if I give if just a little gas, it bogs down really bad. I'm thinking TPS but I was going to see if there were any other thoughts. Problem number two: I rebled the clutch and shifting seems to be getting better, but I still can't reach reverse. Any thoughts? Thanks in advance.
1990 GSX
PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come.
Old 10-16-2006, 01:36 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Need help working kinks out of the GSX
Problem #1 sounds like old gas. Somone just had this problem on here like a week ago...
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-16-2006, 02:37 PM
I kinda figured that old gas may be part of my problem... I syphoned out as much as I could (too lazy to drop gas tank), and then filled it up with new gas and a couple bottles of heet.
1990 GSX
Old 10-16-2006, 04:02 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Check the tension of your throttle cable.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
