Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 10-16-2006, 12:57 PM
eugene_mathena eugene_mathena is offline
My ZX2 has a major PROBLEM. Need HELP!
I have a 2001 Ford ZX2, 135 k miles. It all of a sudden lost power and makes a loud grinding noise when accerlerating. The noise sounds like it is coming from the back of the engine just below where the air intake is. It sounds like metal bolts shaking real hard or gravels vibrating loudly and now the car sucks a lot more air for some reason. I have no idea what it could be. PLEASE HELP!
Old 10-16-2006, 04:23 PM
buttnekked buttnekked is offline
Re: My ZX2 has a major PROBLEM. Need HELP!
The transmission is located under the airfilter box. Does the car make noise in neutral or park? Engine would most likely make noise at higher rpm's sitting still as well as moving.
Old 10-16-2006, 04:42 PM
the sound comes from underneith the intake or it sounds like it does. It will make the sound parked or moving in gear or out. Its an automatic.
Old 10-16-2006, 08:14 PM
definitely sounds like engine or maybe accessory problem. You can use a mechanics stethoscope to help isolate the location of the noise. Also some basic checks; belt ok, fluids contaminated or have metal present. Doesn't sound good.
Old 10-17-2006, 12:26 AM
All fluids are ok and no metal in them. The sound appears when the gas peddle is pushed in gear or out of gear. Imagine taking a tin can with nuts and bolts in it and shaking it real fast and hard, that's what it sounds like. Power loss is present bigtime.
Old 10-17-2006, 05:10 PM
definitely sounds engine related but hard to pinpoint without teardown or diagnostic tools. Good luck with it.
Old 10-18-2006, 04:14 PM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
accessories are on teh other side of the motor.
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 10-18-2006, 07:11 PM
very true but sounds radiate, especially through metal, hence the reference fort using a stethescope to isolate the source. Grinding could be a bad bearing an alternator etc... I do believe however it's probably internal engine or torque converter. Without actually seeing the car it's hard to give a definitive answer.
Old 10-19-2006, 07:54 AM
Hey guys thanks for the help. Keep the possibilities coming, because I'll look into each one and narrow this thing down. I went and had a dianostic check and "Camshaft sensor" popped up. What does it do and why would that come up? Thanks, Eugene
Old 10-19-2006, 07:02 PM
camshaft sensor helps computer to understand engine position in relation to timing and to help adjust it based on rpms. Not sure if it's related or not but could be that metal in the engine has atuck to sensor causing bad signal to computer.
Old 10-21-2006, 01:17 AM
Markb873 Markb873 is offline
Sounds like a broken flexplate to me. It sometimes sets off "cam sensor" or p0340
Old 10-25-2006, 02:27 PM
bjboertje's Avatar
bjboertje bjboertje is offline
does the car still drive?
it wouldn't with a broken flexplate, right?
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 10-25-2006, 08:28 PM
flexplate breaks in the center usually and yes I have had drivable vehicles with broken flexplate. It will eventually break out the center but not always right away.
Old 10-26-2006, 06:37 AM
I drive it everyday to work and back. I just know it has lost considerable power and makes a grinding noise just beneath the throttle body when the gas peddle is pushed whether it is in park or driving and it sucks in a whole lot more air and it makes it sound like a motorcycle from all the air it is sucking thru the air filter compartment. We gutted the catylytic converter and that wasn't it, we changed plugs and that wasn't it, we changed the camshaft sensor and that wasn't it.............anymore suggestions?
Old 11-13-2006, 12:43 PM
ussamuraimc ussamuraimc is offline
I have the same Problem but itwas right after the timing belt gave its last start. The mechanic told me that the it might have bent some valves. check your timing belt. it shounld be changed every 60,000 miles. My car shakes when its idel and on park even when i start it. it does sond like nuts and bolts being shaked in a can.
