Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 10-16-2006, 07:33 AM
1regal 1regal is offline
Volt light on - Alt & batt OK
I have a 95 SSEi and the volt light keeps coming on. Sometimes it stays on for just a short while, sometimes a long time. I had the alt and battery checked out, and the parts store said both were good. Holding a voltmeter to the battery while the engine is on shows 14volts even when the volt light is illuminated on the dash. Got any ideas?
Old 10-23-2006, 10:57 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Volt light on - Alt & batt OK
try running a new ground wire from the engine to the subframe. If the light goes out, you have a bad engine ground strap.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-04-2006, 06:36 PM
Thanks richtazz but I can't seem to make the light go out by grounding the engine to the chassis. Where exactly is this strap located, maybe I can unbolt it and reattach it at both ends to make sure it's conducting?
