Old 10-16-2006, 12:02 AM
BowtiePowerhouse BowtiePowerhouse is offline
figure this out..
ok. i have no idea what causes this. bare with me. when its wet outside and only when its wet outside, my truck wont go forward. its perfectly normal in dry conditions. the transmission is new, the brakes are all new spare a couple parts. it goes in reverse just fine, but when i try going forward, the rear tires spin before the truck moves forward. ive never heard of water causing the brakes to stick or anything. im so lost.
Old 10-16-2006, 09:29 AM
Bob B Bob B is offline
Re: figure this out..
Sounds like something is sticking or dragging in the front brakes.
Bob B
Old 10-16-2006, 09:57 AM
69Charger 69Charger is offline
Send a message via MSN to 69Charger
like bob said it sounds like the brakes are hanging up.. Check to see if the flex lines are shot or the calipers are stuck
Mark Mcknight
Elmvale Truck & 4x4
(705)-715-7867
Elmvale, Ontario
87 Mustang GT, 5.0L 5 spd, MSD ignition, BBK tubes, flowmasters, tri-ax shifter, 4.10 gears
69 Charger SE, stroked & poked 383,727 over 550rwhp
86 Chevy 2500 4x4 Plow truck, 350/TH400, 8ft fisher plow
Old 10-17-2006, 12:03 PM
when i push the brake pedal about half way down it goes "bang". not very loud but it does make a bang sound. then the truck rolls forward about a foot and locks up again. it feels likes its in the front.
Old 10-17-2006, 12:22 PM
prankstar prankstar is offline
Do your rotors have grooves in them? Is this a 4x4 truck? You should get that truck on jackstand soon as possible. If you have the truck in neutral will it roll?
Old 10-17-2006, 01:01 PM
alblogg's Avatar
alblogg alblogg is offline
Yes you definitely have a caliper hanging up or they might be some sort of debris caught in one of your calipers or pads.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 10-18-2006, 12:55 AM
the only 3 things that arent new are the driver side caliper the brake lines and the master cylinder. since before this i wasnt able to get the full efficiency out of the braking system, i might as well just swap em all. its cheap. should fix it... one would hope..
Old 10-18-2006, 09:10 AM
Actually I would see if anybody standing near could point toward which wheel or end makes the bang.
The rears could also cause this.
I had 90 wt all over the shoes in one wheel and they would stick once applied.
Also drum brakes (rear?) grab better going forward and not as good going backward.
So unless you get help to locate it, Check all four wheels.
Bob B
Old 10-19-2006, 06:15 AM
v10_viper's Avatar
v10_viper v10_viper is offline
Send a message via MSN to v10_viper
Yup I'd check your rear drum brakes as well. My rear cylinders went out in the brakes and that caused them to lock up really bad, once I got moving it was fine but I'm sure that it was major friction going on. replaced the cylinders as well as got a new spring kit and I experienced how much of a difference those rear brakes do make.
Oh and I had first noticed that in our school parking lot leaving one day, because my tires were spinning and I wasnt doing it on purpose and freaked out.
If it is both of your rear tires spinning though, at the same time, then I'd rule out it being anything with the rear brakes.
Wait a minute, you mean to say a bottle of pop is bigger than your engine??
"Pain is weakness leaving your body"
There is NO replacement, for displacement...
2007 Kawasaki ZX10-R S.E.
