Old 10-15-2006, 08:42 PM
black_trucks bump black_trucks bump is offline
help! jimmy wont start!!!
hey i just bought a 1992 jimmy s15 4x4 wit the 4.3 l v6 vortec when i bought it it dident run. just rebuilt the fuel pump and it seems to be working fine i can stick a pen in the pressure testing port and fuel comes out i cant afford to buy a pressure tester and know nobody with one. the spark plugs get spark but its kinda weak and it wont fire up even with starting fluid ive been reading forums for days and its helped me a littel bit but not as much as i need my buddy came over and looked at it and said that the first thing he would do is replace the ignition module (the truck has lik 125000 miles or so) bottom line is ignition module, pressure regulator, polsator, or what what do i do i cant afford to buy anything i dont need somone please help!!! i know theres alot of post on this and iv been reading the shyt out of them and i just cant find nothing that relates to my problem exactly plz help
Old 10-15-2006, 11:23 PM
jammyjim jammyjim is offline
Re: help! jimmy wont start!!!
AutoZone has a lend a tool program. YOu can check their website for a list of tools.
Old 10-15-2006, 11:37 PM
wb8yjf wb8yjf is offline
Bypass that POS pulsator on the pump! Use a piece of fuel line! New pumps usually come with a piece of hose to do just that. Believe me, I just went through this & the new pulsator was the culprit to all of my problems! Borrow a feul pressure (or rent) and hook it to the shrader valve. There is a LOT of info on this site to help you out. Good luck!
Old 10-16-2006, 10:44 AM
the problem with that is i dont know what the pulsator looks like thers three metal lines comin from the tank , two of them got a piece of rubber hose inbetween the metal line for like 3 inches or so looks lik a professional job then the third metal line looks like the person before me just swaped out the rubber hose with another and clamped it down on each side, (the metal line going to the fuel filter still has the original rubber hose you know the kind wit nut like things built int to each sid of the hose is this the pulsator?) and it dosent even fire up on me with starter fluid so dosent it have to be somthing wit the ignition system?
Old 10-16-2006, 10:55 AM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
When you say the spark is week, have you tried new plugs?
Check under the cap, make sure everything is clean.
When is the last time this thing had a tune up?
I would say the first thing to check though is the fuel pressure. You may have fuel but if its not enough youll never get it to fire.
Old 10-16-2006, 11:24 AM
yes, i understand that but even if im not getting right psi it should still fire up at least for a second with starter fluid shouldent it? and it dosent
Old 10-16-2006, 11:58 AM
You really need to check your fuel pressure before you move on. IF your pressure is good, then you move on to ignition. If your getting spark and fuel, you need to check compression. Buy a Chiltons or Haynes or some similar manuel. It will be better than blindly fiddling and will help you to visualize the advice you get here.
Old 10-16-2006, 03:24 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Fuel pressure needs to be checked before anything at all is done. You can get them on loan from some parts stores.
Do you have the TBI engine or the Vortec name plate on top of your engine.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-16-2006, 03:41 PM
i cant find a store that loans one, i just cant get ahold of the tester i just replaced my igniton module and still not fireing , but i just pulled a spark plug and its wet so do this mean im getting fuel to the cylinders? my coil and spark plug wires are all nasty rusted and coreoded inside so could this be the reason for a real weaak spark? oh ya its vortec vin w cpi 4.3 l
Old 10-16-2006, 03:42 PM
Not necessarily. Your turning the engine over which means any fuel that is in the chamber will get pumped out when the exhaust valve opens up.
[This is just a metaphor, please do not attempt!]
Imagine putting an eye dopper full of gas into a 55 gallon drum. Slim chance its gonna ignite with a little spark. Pour a 5 gallon bucket of gas in there and you better not stand over the top of it.
Old 10-16-2006, 05:27 PM
If your plugs are fouled, It could be weak spark or poor atomization from the injectors. I would replace your coil and plug wires weather or not it is the problem. Rust is bad, umkay.
Edit: Also, low fuel pressure=poor atomization=fouled plugs.
Old 10-16-2006, 09:06 PM
BlazerLT's Avatar
AF -Advisor
low fuel pressure = injectors will not spray = no start.
Get the pressure checked and stop assuming what the truck should be doing with low fuel pressure.
Also don't start thowing your money away by throwing parts at the truck hoping it will solve the problem.
Old 10-17-2006, 07:37 PM
ok , i thought id update , today i replaced spark plugs,wires,& coil pack all this cost me 42.50 witchis the same price as a pressure tester (so i feel like a dumb ass seing how this did not fix problem ) and it was the last of my money for a couple days.but i dont feel that bad seeing as how i plan on sellin trucik when i get it started and i kept receipts and it will help and as how i bought the truck for $50 from my freind and its in fairly good condition (ecept for the fact that it dont start) so i guess im just gonna wait till i can get ahold of tester. i might pop off the plenum though and chek for washing.
Old 10-17-2006, 08:58 PM
i need a diagram
ok the 92 jimmy 4.3 l vortec i bought from a freind vin w
4x4 still had this security thingy on it from a second hand dealer ship that dosent car to start if payment is not made welll the car broke down and he made his final payment but never got it in to get the system removed it was tied into the igintion wires under the steering wheel so i ripped it out, well im wondering now if the car still has somthing else they did that i cant see cause it wont get a fire off starter fluid and i just replaced ignition module , coil pack, wires , spark plugs and its just not fireing so what i need is a good wireing diagram so i can check and make sure everything is fine caus the one in chiltons sucks please if ne1 has a ignition wireing dagram post it plzzz help!
Old 10-18-2006, 07:33 AM
Ouch!
Well I wont say it.
What I will say is check the fuel pressure.
