| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Engine swap problem
I have a 92 plymouth laser rs with FWD 2.0. I ordered a engine on line and at first i was delighted but upon removing the bad engine I dicovered it has a 6 bolt flywheel and the new one has 7. What now? Can I just get a seven bolt flywheel and stick her in there?
Re: Engine swap problem
The short answer is No. It's possible but not without alot of work. Your best bet is to send the motor back to where you got it, and have them send you a 6-bolt. It will be alot less painfull that way.
1991 GSX 2.3 Stroker |
Hmm lets see here... There are too many differences between a 6 bolt and 7 bolt to just do that. For instance, things don't bolt up the same at all. You will need to get the 6 bolt to drop right in. If you do the 7 bolt then you will have to rewire the wiring harness to read the crank angle sensor in the 7 bolt instead of the cam angle sensor that is read in the 6 bolts.
-Brian
Yeah, you dont want those CW'ing 7 bolt POS's anyway
. Take it back if you can, if not put 'er on eBay and get yourself a 6 bolt.
