Old 10-15-2006, 07:15 PM
jusg19 jusg19 is offline
Alternator Bolt Broke HELP
90 crx si with the stock D16. I was able to get the top two bolts out, but the bottom one snapped. The nut on the tranny side came off, but when I tried to back out the bolt the head snapped off. The body (from just below the head to the end) is stuck in the alternator and I can't get it off. I tried to get at the bracket bolts to just remove the whole thing, but I can't get at the one behind the alternator.
Anyone have any idea what to do?
Old 10-15-2006, 07:53 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: Alternator Bolt Broke HELP
beat it with a hammer. lol
-tony-
2000 honda s2000
Old 10-15-2006, 08:17 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
you need what's know as a stud extractor. you drill a small hole into the broken bolt, insert the extractor and turn, it removed the broken stud easily.
stud extractor:
http://static.zoovy.com/img/usfreigh...a6pcspiral.jpg
Seatbelts Saved My Life
Old 10-15-2006, 08:19 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
That or a left-threaded drill bit. As it digs in, it will pull the bolt out.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 10-15-2006, 08:41 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
The real question is, why were you doing all that to replace the alternater belt?
Old 10-16-2006, 07:46 AM
It's the bolt, not the belt....I've mistakenly read it as belt a couple times too.
I'll try the extractor tonight and post how it worked. Does anyone know how to get drilled hole in the center and avoid the drill bit "walking"? Everytime I use it I get really close to the edges.
Old 10-17-2006, 06:42 AM
you use a centre punch.
