Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-15-2006, 08:08 PM
fufu valve fufu valve is offline
97 aurora no start
My wifes 97 doesn't want to start.When you turn the ignition to start you can hear the fuel pump run and a couple of relays clicking.the volt meter goes to discharge. i read a couple of other threads with the same problem but have pretty much ruled those fixes out The battery is reading 12-12.2.Replaced the starter thinking that was what it was. There is a black relay on the fire wall in the middle of two other relays (engine compartment)that clicks when i try to start it.Was wondering if any one knew what the relay was for and if this could be the problem. Any other ideas would be appreciated.
Old 10-15-2006, 08:52 PM
kiway22 kiway22 is offline
Send a message via Yahoo to kiway22
Re: 97 aurora no start
If the starter doesn't turn the motor over, then it sounds like the battery or connections between the starter and battery.
Old 10-16-2006, 07:27 PM
have to take the intake manifold off again and see how many volts if any are getting to the starter thanks
Old 10-31-2006, 11:14 AM
Sled Head Sled Head is offline
I also have a 97 Aurora that all of sudden will not start did you ever get yours fixed and if so what was the problem. Let me know
Thanks
