Old 10-15-2006, 06:30 PM
Spitfire7175 Spitfire7175 is offline
Question about idle speed
I have a 1996 S10 w/ 2.2 4cyl. manual trans. I have just installed a tach and need to know the idle speed for this engine. The tach is giving me a very high reading, from 1500 to 1000 depending on which setting I have it on. (2 cyl, 4cyl, 6cyl, 8cyl) I have installed an adapter because it is the DIS ignition system. I have looked everywhere and I can't find the idle speed anywhere online. If anyone could help me out it would be appreciated.
Old 10-15-2006, 07:51 PM
Cloud Strife Cloud Strife is offline
Re: Question about idle speed
My 99' LS reads about 700 RPM. It was lower when I didn't have a Cold Air Intake kit installed.
1999 Blazer 4x4 LS "Blackie"
Monroe Reflex Shocks
Moog U/L Ball Joints
K&N FIPK Gen 2 Cold Air Intake
Flo-pro Soundpro exhaust
Optima Redtop
132k miles and still rolling....
Old 10-16-2006, 03:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
I think it should be around 700-750rpms.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 10-16-2006, 05:43 PM
Thanks. I will check into it.
Old 10-22-2006, 08:02 AM
Blue Bowtie's Avatar
Registered Offender
My '96 2.2 manual trans idles at about 900-950.
Old 10-22-2006, 09:37 AM
BlazerLT's Avatar
AF -Advisor
That's pretty hi bro.
Old 10-22-2006, 08:40 PM
Registered Offender
That's what the factory, in-dash "tachometer" shows. Data scans show about 740-745 RPM at temperature. That thing the factory put next to the speedometere is more a part of a trim package than an instrument. It almost kind of moves around relative to engine speed - Almost.
That aside, it does start at about 1150 (actual, not indicated) until the CTS reads over 104°F, where it begins to drop slowly.
Old 10-22-2006, 09:15 PM
BlazerLT's Avatar
AF -Advisor
You are right. Not overly accurate.
750rpms sounds perfect.
Old 10-22-2006, 10:10 PM
TheBrettster TheBrettster is offline
AF Premium User
On my sonoma its at 900 Constant around 1100 when cold.
2001 Chevrolet Blazer 4x4 LT
Mods = TPM , Intake , Exhaust , Bearings , Polished Crank , Heavy Duty mounts , Complete rebuild done Oct '07 , HD Sun Shell .
Sound = 4 12" Kicker SoloBarics L7
2000 Watt Performance Teknique Amp x3
Old 10-23-2006, 02:49 PM
BlazerLT's Avatar
AF -Advisor
4 banger?
Old 10-23-2006, 04:08 PM
AF Premium User
Yea 2.2
Old 10-23-2006, 04:56 PM
BlazerLT's Avatar
AF -Advisor
I still think that is a little high, but ytou might have the same thing as Blue Bowtie has that it is 750rpms, but showing 900 on the tach.
