Go Back   Automotive Forums Car Chat > Honda > Integra
Old 10-15-2006, 06:15 PM
whamo whamo is offline
No Spark
Alright so i just finished swapping cams and adjusting the valves. It drove fine until i went to check my timing. i hooked up the light and the car was running. next the plug wire slipped off the connector and was arcing onto the top of the valve cover. as i went to turn the car off it shut off before i got there. next thing you know there is no spark. could i have blown a fuse somewhere and if so where?. --thanks
Old 10-22-2006, 03:00 PM
turbosnail turbosnail is offline
Re: No Spark
check the fuses first and if all ok check your ignition coil may be a blown coil
hope that helps
Old 10-22-2006, 11:50 PM
Re: No Spark
The fuses are good so i checked the coil, and the resistance was out of spec. and the ignitor lacked continuity. thanks though
