Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-15-2006, 06:07 PM
90laser1.8 90laser1.8 is offline
91 talon engine problems
Ok... i'm looking into buying a 1991 eagle talon... it has the 2.0 turbo.. with aftermarket turbo on it... i have the 1990 laser 1.8 now.... the talon... he was driving down the road and it shut off.... it did not blow motor... or snap timing belt... but.. while cranking the engine to start. the cams do not move... once u leave up on the starter they start to spin... for like 1 sec... then they quit again... he's asking an unbelievable price for it... what could be the problem... and is it worth $300.. please help me... u guys did it before.. thank you
Old 10-15-2006, 07:16 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: 91 talon engine problems
How is 300 an unbelievebale price? I would say its a good price so long as the timing belt isn't broke. But, you realize the only thing that makes the cams turn IS the timing belt. So right there you know somethings majorly wrong with it.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-15-2006, 07:23 PM
i know the timing belt isn't broken... we found out its the teeth on the belt are stripped... the cams didn't actually turn... they rocked... so.. now my only question is... if the engine would be messed up...
Old 10-15-2006, 07:26 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
If the starter is cranking over and the cams arent spinning, you've got either A) a broken/jumped timing belt (99.4% chance) or B) messed up starter gear or flywheel. I think $300 and a few hours of elbow grease is an excellent way to get into DSMing, I would get it, fix the problems, sell the 1.8, and enjoy the fruits of your labor.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 10-15-2006, 07:35 PM
Well if it isn't broken and your missing teeth on it then what do you call that? Perfectly fine? No, we call it a broken timing belt and if the belt is spinning and just rocking the cams then your crank has been turning fine. Hence skipped timing and bent valves. Yes the engine is messed up.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 10-15-2006, 07:47 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
I agree with what thor said. Especially if this car is in good shape body wise, you might have yourself a steal for 300 bucks. The shell alone is probably worth 300 bucks. You are probably looking at a motor rebuild if the timing belt spun. The pistons probably hit the valves and bent them. As long as the pistons aren't damaged and the valves are just bent and head not destroyed, it's not a very expensive fix.
If I was in your situation I would buy this car.
1991 GSX 2.3 Stroker
Old 10-15-2006, 07:56 PM
no... alright... the teeth on the belt are stripped down by the crank... not on the crank gear... or the cams... the belt alone is stripped...also... while engine is cranking there is no tapping or knocking sound... either way it doesn't matter even if it did bend valves cuz i can get the head done for 150... i just didn't know if it was worth 300 bucks...
Old 10-16-2006, 12:16 AM
defiancy's Avatar
If the belt is stripped than the valves are most likely bent.
No big deal. I would Def say it's worth 300, especially if it's an upgraded turbo, you might be able to sell that for more than 300
