Old 10-15-2006, 02:36 PM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
swap question
I finally got my hands on a b16 head (I got the block and head for $250 and block is for sale) I am currently running a b20 off of a obd-0 91 integra ecu. Is it true that i can use the 91 integra dizzy for my b16 head?? if not which on should i use? Because Id rather use the one i have on my b20 due to that i just bought it new like 2 months ago. i am open to any suggestions that u guys might have when it comes to my b20 vtec conversion... thanks for the help!!
°Sä®GëNTö69°
B20B POWERED '91CRX SI
Old 10-15-2006, 02:52 PM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
Re: swap question
as far i can can see, no you can't use your b20 dizzy. but if your running obd-0 already, i can help, i got a obd0 dizzy for sale along with a pw0 ecu.
took them off my swap, i went obd1.
-tony-
2000 honda s2000
Old 10-15-2006, 05:03 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: swap question
He is asking if he can use his obd-0 Teg Dizzy, not the B20...atleast that is what I think he is meaning. I believe you can, but not positive.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-15-2006, 05:16 PM
Re: swap question
i dont think so. the bolt pattern for the distributor should get in the way of the vtec solenoid. i think. it's been a while. unless it's agsr dizzy. or you modify it, without breaking it.
-tony-
2000 honda s2000
Old 10-15-2006, 05:20 PM
Re: swap question
it's a non-vtec distributor, the vtec solenoid is in the way and you won't be able to use it unless you do some cutting (not recommended). you will need a b-series obd0 VTEC dizzy if you want to stay obd-0 and go vtec, you will also need a b-series VTEC ecu.
let me know if you need one or the other i have both for sale.
-tony-
2000 honda s2000
Old 10-15-2006, 06:48 PM
Tony's Avatar
TLD Member #1
Re: swap question
Alright, thanks for correcting that. i didn't know for sure, haven't dealt with the B series much yet, been obsessed with the D series right now.
Tony
Old 10-15-2006, 07:52 PM
Re: swap question
the (mounting holes?) that hold the dizzy on are different between vtec and non vtec b-series because the solenoid gets in the way.
-tony-
2000 honda s2000
Old 10-18-2006, 07:09 PM
Re: swap question
you are right. because the dizzy that came with b16 i bought was modified. Since i am going to stay obd-0, from what car whould i get the dizzy from? also what are the differences between the ecu (pw0) u have and a pr3 that my friend told me to use??
°Sä®GëNTö69°
Old 10-18-2006, 10:51 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
Re: swap question
For a no-sweat affair, you want the jdm 89-91 B16a distributor. Or, you can just run the 90-91 OBD0 integra distributor and cut off the front mounting tab. The OBD0 B16a and OBD0 B18a distributor are the same exact distributor, minus the mounting tab locations.
I'm using a 90 integra distributor w/ the front leg cut off on my lsvtec in my 88 crx. No leaks. No problems.
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 10-18-2006, 10:56 PM
Tony's Avatar
TLD Member #1
Re: swap question
See thats what I was thinking, but didn't know for sure....I'm rustier on this stuff than I thought.
Tony
Old 10-18-2006, 11:56 PM
Re: swap question
well that's why i said you would have to modify it.
plus i'm trying to get rid of my obd-0 dizzy and pw0 ecu
-tony-
2000 honda s2000
Old 10-18-2006, 11:57 PM
Re: swap question
a pw0 and pr3 are the same basically. ask bambam for more info though. cause i don't got a clue beyond that.
-tony-
2000 honda s2000
Old 10-19-2006, 12:01 AM
bambam89lx's Avatar
AF - Advisor
Re: swap question
In stock form, they're basically the same. But, if you ever plan on being able to reprogram your ecu, go with the PR3. There's too many headaches associated with the PW0 that makes it a little more difficult to chip and tune.
Old 10-19-2006, 12:04 AM
Re: swap question
awww but i need to sell mine.
-tony-
2000 honda s2000
Old 10-19-2006, 12:08 AM
bambam89lx's Avatar
AF - Advisor
Re: swap question
Well it's not impossible but a PITA.
