Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 10-15-2006, 02:36 PM
mikeinnc400 mikeinnc400 is offline
2003 Rodeo Runing rough
Ran fine when brought it home last night,started it up and like its hitting on 3 cyclinders. Service Engine light comes on and blinks.
Anyone have any ideas?
Old 10-15-2006, 03:40 PM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
Re: 2003 Rodeo Runing rough
Get the codes read.
2000 VW New Beetle TDI
2007 Honda CR-V
Old 10-15-2006, 05:00 PM
trooperbc's Avatar
trooperbc trooperbc is offline
sure, get the codes read as above. i'd assume misfire for a particular cylinder or random misfire, from your stated condition.
so at least while waiting to get the codes read, pop the hood and have a look around. all wires fully seated? hoses? etc
otherwise, wait for the codes to narrow the possibilities -- unless you have a 3-cylinder engine. . .
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 10-15-2006, 06:24 PM
surferfletch surferfletch is offline
Coil pack is a possibility. I just went through this last weekend. Went from perfect to really rough in one startup. I started pulling plugs when it happened to find which cylinder was missing. I have a '97 which has a coil over each individual cylinder.
1997 Isuzu Rodeo LS 3.2L V6 SOHC 4L-30E Dueler Alenzas 4x2
1997 TJ Sport 4.0L D35 rear 5 spd 31" Dayton Timberline ATs
1996 VW Jetta GLS 2.0L 5 spd
Old 10-15-2006, 06:30 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
An '03 would have ION sensing too so the proper spark plugs would be critical. I dont know if that year would suffer from the IMG problems, could be something to look at.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 11-19-2006, 01:22 AM
joe wonder joe wonder is offline
i have the isuzu rodeo 2000 3.2 v6 auto trans trouble code show 0507 "idle air control is higher than expected" but i can't find the idle air control sensor.The repair book show just right at the side of the throttle body on the 1997 but i coudn't find it on the 2000.Can anyone tell me where exactly it is?I really appreciated.
Old 11-19-2006, 06:24 AM
rodeo02 rodeo02 is offline
Mike, do you have the 3.2L in your 2003? Do any work on it recently? As indicated, a *flashing* CEL always means a misfire. Most common cause on the 2000+ is installing the 'wrong' sparkplugs. Like Gizmo says, could be a failed ion sensing unit. If that CEL is accompanied by a reduced power light, it could also be a throttle by wire issue (if it's a 3.2L). Something is amiss as a failed MAF, O2 sensor, etc.. wont cause such a drastic issue on a cold start.
To Joe the hyjacker (kidding!), you are correct. There is no IAC on the 2000+ 3.2/3.5. I beleive that code is telling you the idle speed is too low. You could try a throttle body cleaning, but this might require a reflash of the PCM.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-20-2006, 11:31 AM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
img or incorrect plugs
