Old 10-15-2006, 02:15 PM
dsm3000gtvr4's Avatar
dsm3000gtvr4 dsm3000gtvr4 is offline
valve tapping... how to fix?
my valves keep tapping in my baseline 95 3000gt and it seems like it keeps getting worse. i dont know if my oil is too thick or my valves are broken... any suggestions?
Old 10-15-2006, 04:05 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
Re: valve tapping... how to fix?
Are you sure its your valves and not lifter tick?
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 10-15-2006, 05:03 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
^Definately could be lifter tick. Read page 1 (and pg 2 for that matter) and read the part on lifter tick.
Old 10-15-2006, 06:32 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Have you looked at your timing? did your belt slip? or is it lifter tick?
Old 10-15-2006, 06:53 PM
StealthModifier StealthModifier is offline
swap in some 3rd gen lifters. an change ur oil to 20w50
Old 10-15-2006, 07:27 PM
AutostradaVR4 AutostradaVR4 is offline
15w50 does the trick for me.
hey DSM, where do you live? im in Albany NY. If your close, buy 3G lifters and we can swap both of ours together lol.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-15-2006, 09:57 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
DSM, SL3000gt is referring you to our FAQ thread. the lifter tick topic is covered in there. there are a few options, the first of which should be to change your oil. you might try a different weight, but just new oil can make a difference.
oh, and i guess you currently have/previously owned some DSM cars? but FYI, the 3000GT/Stealth cars are not DSM cars. tho i'm sure you know that.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-15-2006, 11:38 PM
i was thinking the same thing...
Formerly BlinkRA182
